Question about that GM twin turbo L-98
Old Apr 24, 2003 | 07:04 PM
Y body bill's Avatar
Some of you will probably remember those pictures of the Twin turbo L-98 that GM put together back in the 80's. I believe the pictures came from the Corvette Museum.
Does anyone have any idea what size the turbos were on it?
And would say a pair of T-3's be the equivalent to those?
I am having tourble finding the pics on the net again or else I would of posted them here.
Old Apr 24, 2003 | 08:19 PM
True Power's Avatar
Just to clarify, GM didnt put it together. Lingenfelter did
edit - Gale Banks also did a TT system
Old Apr 24, 2003 | 10:42 PM
LIL QIK's Avatar
I thought the pictures of the twin turbo corvette was the Callaway system.
Old Apr 24, 2003 | 11:17 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
You can find pics of the TT L98 powered TA out of pontiacs skunk works division below. While I know your looking at the vette, this is a similar setup and engine. 200mph capable with NO aerodynamic mods!
http://www.yearone.com/enthusiast/ar...et/blueta.html
Old Apr 25, 2003 | 12:55 AM
So you are saying this is LPE's work?
Old Apr 25, 2003 | 07:52 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
The pictures posted above are of the Callaway engine in the C4, not the twin turbo Firebird Pontiac built (blatantly copied from HPP mag, and posted here-http://www.skulte.com/other.html).
Andris
Old Apr 25, 2003 | 10:31 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yeah askulte I saw that one, it still piqued my interest and shows the ability of GM to waste money on R&D then forget about it because they are like a deranged kid on ADD that wont listen to reason.
Attached Thumbnails Question about that GM twin turbo L-98-tt92fbirdfromgm.jpg
Old Apr 25, 2003 | 11:55 AM
dgoodhue's Avatar
That picture is not of a callaway TT car either (turbo mounted too high & the dual IC are suposed to be mounted on the valve covers). It looks like to me some of the TT corvette projects GM had in the mid 80's. GM sent some of the cars to the magazines...
Old Apr 25, 2003 | 07:43 PM
92Z's Avatar
92Z
Here's a picture I found in a book. It says that it is a GM prototype.
Old Apr 26, 2003 | 03:08 AM
So can anyone take a guess as to what size turbos those are?
Would T-3's be too big to fit level to the top of the TPI plenum?
Old Apr 26, 2003 | 03:44 AM
83 Crossfire TA's Avatar
It’s not a question of GM being ADD, it was a design exorcise to determine what can be done with the technology. It’s doubtful that they’d ever put something like that in production for both insurance and warranty reasons. It’s the same reason that everyone is so impressed with Chrysler actually building the vipers. It’s not that it’s a great technological feat, but that that amount of HP just opens the door to loads of problems that make it impossible for a large company to actually make a real profit on the car.
FWIW, I thought that you guys were talking about the TT that was GM built that’s in the corvette museum that looks significantly different then both of those pictures…
BTW, all the pics that have been attached so far appear to be using assorted TO4’s…
Old Apr 27, 2003 | 03:37 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I do notice the brackets on that last picture are vette?
Old Apr 28, 2003 | 02:26 AM
Yes they are vette.
http://www.corvettearchive.com/images/1985/page4.jpg
here is a crappy pic of it in the car.
Reeves says these GM built TT L-98 vettes burned to the ground.
I read that GM built 14 of these TT vettes, and destroyed them, to go with the LT-5 program instead, giving the R&D for the TT to Callaway.
Old Apr 28, 2003 | 02:30 AM
Those defently look like the GM TT's I know of, do you have pictures of soemthing else? I would like to see them.
Old Jan 24, 2004 | 04:19 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
The turbos on the GM engines appear to be T3s due to the internal waste-gates. However, they are not the common Garrett T3, maybe a Warner Ishi or IHI. The T4 family of turbos don't have internal wastegates, except for the T3/T4 hybrids (which is based off a T3 anyway).
T3 turbos will fit on top of the valve covers, and below the top of the plenum. My TT TPI in an 89 IROC has no hood clearance issues. Heat is the big issue with the turbos- I think GM also realized that- note all the heatshields and hood louvers on that Vette.
Here is a pic of my engine with modified camaro manifolds- you can sorta see the turbos are below the top of the plenum.
Old Jan 24, 2004 | 06:24 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Same engine with sign visible:
Old Jan 24, 2004 | 06:32 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Note the picture under the engine stand in my previous post ...
I have a picture of that engine in a C4 Corvette somewhere
Old Jan 24, 2004 | 06:45 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
I found it ...
Old Jan 24, 2004 | 06:50 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
This is the turbo location of the Callaway Twin Turbo
Old Jan 24, 2004 | 07:18 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
One more picture ...
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
And some text
Old Jan 24, 2004 | 07:26 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Corvette Twin Turbo V6 mentioned in text:
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Corvette Thumper mentioned in text:
Old Jan 26, 2004 | 12:34 PM
89JYturbo's Avatar
Wow. I didn't know GM was ever into turbos like that. This is some pretty nice hardware.
Old Jan 26, 2004 | 06:50 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Engine by Ryan Falconer??!?!? Of the off shore racing Falconer company!!!??? They are the ones that built that V12 for GM that they put in the "snake skinner" a few years back to trounce the then "new" vipers in a C4 body. I can't remeber if it was that one or some other GM stripped out concept car that was stolen by some youngsters and led police on a very long high speed pursuit until it ran out of gas not far from where it was stolen.
Old Jan 26, 2004 | 08:47 PM
406-IROC's Avatar
Car: '86 Camaro
Engine: 406 Small Block
Transmission: 4 Speed
Axle/Gears: 3.45
The Snake Skinner Corvette that was stolen by those guys, was a white corvette.... with a modified LT-5, and Kelvar (lightweight) hatch.
Ryan Falconer's V12 Corvette (nicknamed Conan the Corvette) was red, with the entire front end extended eight inches so the small block and a half can fit.
Old Jan 27, 2004 | 12:01 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I knew I was remembering it wrong. Im not sure what is crazier, that it just popped into my head, that someone else remembers it, or that someone else remembers it precisely as that
Old Jan 27, 2004 | 12:15 AM
406-IROC's Avatar
Car: '86 Camaro
Axle/Gears: 3.45
LOL.......
I went to a car show back in the mid-90's, and they had a bunch of experimental Corvette's on display. Some of which were, "Snake Skinner", "Conan", "Big Doggie", "Black Widow" etc....
The reason why I remembered Conan pretty well, is because it made that much of an impression on me. That freaking thing was unbelievable, and it had chrome side-exhaust pipes.
Snake Skinner too. It was a 1989 Corvette, that GM was using to study 'reduced weight' advantages for the Corvette's. But of course, none of these things ever made it into production..... which is typical, especially for GM!
Old Jan 27, 2004 | 12:33 AM
406-IROC's Avatar
Car: '86 Camaro
Axle/Gears: 3.45
This pic is without the side chrome exhaust pipes...... but I have a pic from my own mag if anyone is interested in seeing that employs them.
http://www.vettextc.net/NCM/Conan-V12.jpg
bjpotter
Jan 22, 2019 12:27 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
fasteddi
Sep 2, 2015 10:29 AM
PestilenceIV
Aug 20, 2015 03:32 PM
redmaroz
Aug 16, 2015 11:40 PM
