Accel Gen VII
Old May 8, 2003 | 05:27 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
Accel Gen VII
Hello all,
I just installed the Accel Gen VII in my '89 305 firebird and the car runs great. The problem I am haveing is my Spedo is not working. All wires are hooked up to the tranny. When I turn the key the spedo needle maxes out, then back to zero and stays there. Any suggestions on getting the spedo to work.
Brad
Old May 8, 2003 | 07:08 PM
maniacc's Avatar
This question would be better asked over in the DFI forum.
Did you perform the install yourself, i'm asking cause i have the new DFI gen VII w/wb 02 and am getting ready to install mine. But i have alot of questions. that i can't seem to find answers for in the software help section.
My '88 IROC has a cable driven speedo...fwiw.
later
larry
Old May 8, 2003 | 09:31 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Its fixed,
Had to put ground on the yellow box. I did not do the install, the computer guy spend about 5 hours on the dyno making the map. I asked alot of questions also, however I will answer all that I know of.
Brad
Old May 9, 2003 | 05:52 AM
maniacc's Avatar
congrats on figuring out your problem...
First Question that i have is what is the STI wire for?
later
larry
Old May 9, 2003 | 06:22 AM
88GTAinRI's Avatar
From: Ocean State, lil Rhody, the biggest littlest state in the union, Rhode Island
Car: 1988 GTA Black/Gray
Engine: Blown 355
Originally posted by bluegoose
Its fixed,
Brad
Brad,
I just finished F.A.S.T. install and I am awaiting dyno time to tune. My speedometer is also inoperative after removing the factory computer. Where is this magical yellow box and where do I ground it?
Thanks,
Hank O.
Old May 9, 2003 | 06:58 AM
bluegoose's Avatar
Car: Firebird
Engine: 383
Hank,
Check out this link http://www.hioutput.com/tech/speedo.html
The yellow box is under the passenger side kick plate next to your old ecm. Once I grounded the unit the spedo worked like a champ. Any more questions just ask. Good Luck
Brad
Old May 9, 2003 | 04:02 PM
aDFIguy's Avatar
Car: GTP
Engine: L67
STI = Self Test Input.
Hook a lamp/LED up to the Malfunction Indicator Lamp (MIL) Output and when you ground the STI line, error codes will be flashed out on the MIL line. You could also hook up the MIL line to the idiot/SES indicator on your dash (if you have one).
Old May 9, 2003 | 06:37 PM
maniacc's Avatar
thanks aDFIguy...
Is there a chance that Accel is going to send out printed version of the wiring diagram.
later
larry
Old May 9, 2003 | 08:45 PM
88GTAinRI's Avatar
Engine: Blown 355
Hank,
Brad
Brad,
Thanks a ton. You don't even know how much time you just saved me. I was just getting ready to study the wiring diagrahm for the speedometer. Thanks again!
Hank O.
Old May 10, 2003 | 08:32 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Hank,
No Problem!!!
Brad
Old May 12, 2003 | 11:13 AM
aDFIguy's Avatar
Car: GTP
Engine: L67
I think about as good as you will get is the electronic version that is included with the latest version of CalMap.
tazs2000
Jul 15, 2017 08:44 AM
BAMiller
Sep 14, 2015 06:38 PM
hydrolic144
Aug 29, 2015 04:14 PM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
marcusaw
Aug 10, 2015 08:13 AM
