Hope this stops the problem I have with tubes popping off
Old May 9, 2003 | 09:55 AM
Guido's Avatar
Car: 2000 Trans Am
Was in the garage until 11:30 last night finishing this mess up.
If the rain holds off tomorrow, we will be testing @ Tri State in Ohio.
Old May 9, 2003 | 12:04 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
good job I hope so too
Old May 9, 2003 | 01:44 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
At this point it might be easier to just weld the pipes together!
Good luck with your next run.
I must say I had my first experience with blowing off IC piping last night. The MBC in the Talon isn't adjusted properly so I was running 20+ PSI When that coupling let go, I thought the engine had exploded.. not a nice noise.
Old May 9, 2003 | 02:05 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
when you goanna try it out?
Old May 9, 2003 | 02:27 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
If that doesn't work, I don't think anything will. Good luck. Can you get more video of the next outing. I want to see that car run so bad, I am almost willing to make the trek to Ohio.
Old May 9, 2003 | 02:28 PM
MikeC.86Roc's Avatar
Ahh yes, I notice that trick from maximum boost I am reading now. As it turns out I was just reading the intercooling section last night and I remember that one fresh. Looks good and it's gotta be a solid way to hold the piping in place at the joints.
That book is so full of awesome information I could hardly believe it when I started reading. It's just hard for me to keep from getting overwhelmed at this point with all the information. Makes those of us who are anticipating a TT project realize just how much time, effort, money and research are involved in making something like this come together.
Old May 9, 2003 | 02:31 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
never mind I saw.
Old May 9, 2003 | 05:14 PM
Guido's Avatar
Car: 2000 Trans Am
We got video of the last time I was at the track of the car idling in the pits, pulling away from the trailer and making a blast to about the 300 foot mark and then coasting the rest of the way. LOL
Old May 9, 2003 | 05:23 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
where?
Old May 11, 2003 | 03:24 AM
83 Crossfire TA's Avatar
FWIW, most in the know look at that book as a little bit of a joke, there are parts that are more opinion then fact, and some that fly in the face of epirical evidence.
If you want a more true to life take on turbocharging I'd suggest McInnes (written by an actual turbocharger engineer that holds a bunch of patents...)
Old May 11, 2003 | 03:35 AM
Damn Guido, I'm dissapointed...
Pull all those off and grind nice rounded edges so they don't look so... so... geeze, I don't even know the word for it.
Oh, and put them on a drill press and relieve them of some of that weight...
BTW... Nice
I probably spent an hour last thursday night grinding 2 grooves around every pressure side fitting on my brother's car for the same reason. also ended up cutting grooves in the blower pulley to make it grab the belt better. Of course, after that I spent at least as much time either polishing or painting everything that I touched...
Old May 12, 2003 | 07:57 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Hey Little Big Bud
Did everything hold together on Saturday?
Andris
Old May 12, 2003 | 08:41 AM
Guido's Avatar
Car: 2000 Trans Am
It rained.
I did get some new tires on the front of the daily driver though. LOL
Going Wednesday unless it friggin RAINS AGAIN!! The story of this May.. rain. I finally have the car in tip top shape and then **** garbage. I cant win.
Old May 12, 2003 | 09:18 AM
MdFormula350's Avatar
nice work, i think they will stay together now
Old May 12, 2003 | 10:33 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
hey it snowed here on the 10th
Old May 13, 2003 | 08:52 PM
TwinTurboROC's Avatar
It rained.
F that, the story of this year... RAIN!!!!! Summer is offically a week, not a season.
Old May 15, 2003 | 10:03 PM
HotRod's Avatar
Car: 87 GTA
Engine: Eaton Supercharged 350 TPI
Since we are also talking about books can anyone recommend some good ones for turbo and/ or super aplications. I am going to be starting my new motor build up at the end of summer and want to do a little research first. By the way, I am going to have to come and watch you run sometime Guido, maybe I will have my together and you can give me some pointers as I am still fairly new the the drag racing scene. Thanks,
Tyler "Cafe"
Old May 16, 2003 | 07:36 AM
Guido's Avatar
Car: 2000 Trans Am
Ive got the macguiness book at home (that was mentioned above) and it was a little help. there is another book out there by corky bell i think its called maximum boost. Ive never seen it before but I think amazon has it. I learned most of what I know by checking out other cars on the web and at the races.
Ill be at Edgewater tonight Tyler and Tri State tomorrow (i hope). If you arent to busy with the "cafe" you should come out.
1992 Trans Am
May 10, 2023 07:19 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
Bryan F
Aug 18, 2015 02:28 PM
