When things go POP!
I was hoping I wasn't about to see pieces of the motor on the ground when i read your topic.
Glad to see it was only a connector! If you haven't already bought the right connectors, I have a few sections of 3" and 4" reinforced silicon connectors I could part with pretty cheap. Let me know, I can cut off however much you need.
Glad to see it was only a connector! If you haven't already bought the right connectors, I have a few sections of 3" and 4" reinforced silicon connectors I could part with pretty cheap. Let me know, I can cut off however much you need. TGO Supporter
Car: 1992 B4C 1LE
actually I just hope it didnt cost too much, I see what appears to be a rubber union but the way it is blown eludes to it being something else?
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Thanks BlownBird... but the tubes are 2.5 inch...
It was the connection from the blower discharge to the IC tube, guess too much heat and pressure found a weak spot.cheers, Bob
I'm not sure what he used to replace it, but if you go to a transport truck store, you can get 4' lengths of radiator hose.. They are very very tough and work awesome.. Plus, it only costs around 35 bucks (canadian)... better than paying like 20 bucks per connection for the flashy colored stuff....
Cheers,
Cheers,
Car: 84 SVO
Transmission: WCT5
Originally posted by D M N
couldnt you use plain exhaust pipes or is that too weak
Iroc8t8
May 4, 2026 08:09 PM
