super ram wont fit, those with superrams help please!
Old Jun 10, 2003 | 11:32 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
please check it out HERE
Old Jun 11, 2003 | 12:34 AM
BlownBird's Avatar
I read the other post you refered to, and the first thing that came to mind would be the trans mount. Just for laughs, take a look, It almost seems if the motor is "leaning back.
Just a thought. If it works, be sure to tell the guys in the other post .
Old Jun 11, 2003 | 12:43 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yeah its energy suspension too, and its kind of tall, not short as well its just the way I took the pictures. It doesnt appear to be leaning back in person but if changing the mounts is what it takes then I guess I better get busy with a jack and buy some stockers?
Old Jun 11, 2003 | 04:53 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
I was using the Anchor brand mounts and never had any clearance issues. I had about 1 1/2" between the plenum and wiper motor.
Old Jun 11, 2003 | 05:32 PM
88GTAinRI's Avatar
From: Ocean State, lil Rhody, the biggest littlest state in the union, Rhode Island
Car: 1988 GTA Black/Gray
Engine: Blown 355
I have the stock motor mounts and a poly trans mount. I had problems with the wiper motor hitting the superbitch. I removed the rubber grommets in the wiper motor and slid them on the bolt, so the back side of wiper motor is bolted directly to firewall. Worked pefectly.
Old Jun 11, 2003 | 05:51 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Originally posted by B4Ctom1
There was atleast an inch of interference which has been reduced to about 3/4 inch by doing the bushing trick.
Old Jun 11, 2003 | 05:56 PM
88GTAinRI's Avatar
Engine: Blown 355
Sorry Dude, my bad, I read it fast.
Old Jun 11, 2003 | 05:59 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
that is fine not critisism all help is welcomed. I have wondered if cocking the motor will help. maybe doing the regular trick on one side of the motor and the whole bushings under the feet on the opposite side. I will have to check for operational binding if it even works. keep the good ideas coming because even though you didnt recommend it, I got more inspiration just reading you guys posts.
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
gixxer92
Sep 1, 2015 04:32 PM
L98GTA87
Aug 11, 2015 06:55 PM
