anyone gone fast w/ 749 ecm
Old Jun 15, 2003 | 07:49 AM
turbotater's Avatar
i see several people have them running in there
cars but i have not found anyone thats has gone
as fast as the n/a cars
now is the reason the sycone typhoon 749 $58
code proccesor is holding the cars back or the cars
are not being built to go that fast ..
no offense to anyone running low 12's or high 11's
as that is an accomplishment to do so
but i am interested in mid 10's as i am installing a
70 mm turbo on my car
you can see some of my turbo work at
http://photos.yahoo.com/turbotater@prodigy.net
click on jimmy car , talon header , lexus header
or whatever you want
thanxs for input
mike
Old Jun 15, 2003 | 11:17 AM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Well I have only had two runs, with 14.4 being the best. But there isn't a reason a 749 will hold me back. The biggest thing currently is the few that are running a 749 now, have only converted recently, and are still shaking their various cars down.
The SyTy guys are running into the 11's. I have heard a turbo Mustang running a 749 was into the 10's but I have never read/seen it.
The ecm is fine.. a near clone to a 730.
The programming is fine.. and completely hacked.
Now just to turn that ET...
Old Jun 15, 2003 | 01:13 PM
turbotater's Avatar
i have a 92 typhoon as well as my
formula and the 11's is the fastest
most sy ty's go before switching to
a fast system .. main reason that i can
find out is the limit of 6 42lb injectors
being the horsepower limiter ..
i am hoping with 8 42lb injectors that
will allow me to get my goal
mike
Old Jun 15, 2003 | 01:23 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
interesting...now what is that turbo off of?
Old Jun 15, 2003 | 06:32 PM
turbotater's Avatar
i am not sure about the compressor housing
i got it from a turbo shop .. it is a 70 mm
wheel with a p trim .96 exhaust side
i will run out of exhaust side before i max
the compressor side out but it should still
be good for 550 - 600 rwhp if pushed hard ..
and i do plan on pushing it .
mike
Old Jun 15, 2003 | 06:59 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
I believe you can get 55lb SAT injectors, and I know some SyTy's are running 72lb P/H injectors after modifiying the injector drivers.
Unfortunitly I have not run one that hard.. so I am unsure as to any tuning issues that may develop.
Old Jun 16, 2003 | 01:03 AM
89ProchargedROC's Avatar
you can run low impedence injectors with LJ's impedence converter....
www.accelertronics.com i think it is...if that doesn't work do a search
Old Jun 16, 2003 | 06:39 AM
turbotater's Avatar
ii have looked at that
both lt1 and ls1 guys have had
success with it ..
it looks like my choice is :
aftermarket electronics
730 and a fmu
749 and a converter to run low impedence injectors
i still am also looking for better deal on the
injectors themselves , someone has to have a set
of good used 50 - 60 lb injectors for sale
later mike
InfernalVortex
Apr 20, 2021 11:31 AM
customblackbird
Oct 1, 2015 04:30 PM
Grumpy
Jan 1, 2002 05:38 PM
TPIJeep
Oct 9, 2001 10:50 PM
Jester
Aug 9, 2001 03:42 PM
