Holley Commander 950 vs 7749?
Old Jun 18, 2003 | 11:17 AM
jdaniel's Avatar
Has anybody out there used the Holley Commander 950 on a spercharger setup or (any setup)? I have the 89 350 w/Miniram and Paxton s/c and do not want to get into burning chips. Is this an easier alternative? Is it a better alternative? Jimmy
Old Jun 18, 2003 | 11:47 AM
lane's Avatar
The reason I bought it was that I didn't want to go through the hassle of burning chips. I have a similar setup, paxton, miniram, afrs, etc. The only drawback is that you will lose your tcc control since you have an auto. I have a 5spd so that option didn't matter to me. You could always use a stand alone tcc setup like the ones people use when retrofitting a lock up style tranny in an older car.
Tuning wise, it's really a no braiiner. Took about 5 minutes to get it running pretty good and about a week of driving around to fine tune it. If you have someone riding shotgun, it will be a lot easier/faster to tune.
Old Jun 18, 2003 | 12:06 PM
jdaniel's Avatar
Lane, does it just plug into your ECM or does it replace your ECM? Do yu then plug a laptop into it? Tell me a little bit about how it works. Thanks, Jimmy
Old Jun 18, 2003 | 01:14 PM
280Z28's Avatar
Laptop plugs into the ECM via the serial port. You get a nice readout on the screen of everything going on in the computer/engine, and any changes are done in real time (as you type them). Someone riding shotgun (or you riding shotgun with someone else driving your car) should be considered a necessity (soooooooooo much easier). It includes datalogging software, but it has a pretty clumsy interface IMHO.
It is a very nice system. The things I wish it had but doesn't are:
Fuel pressure sensor/readout
Distributorless ignition
Wideband O2 <-- !!!
Better control over the idle air control valve (though what it has is not bad, I just think I could get my large cam to idle better with a couple extra parameters. )
Old Jun 18, 2003 | 01:22 PM
jdaniel's Avatar
Thanks but I'm selling all this new stuff and putting on a carb. I don't have near enough time or patience. My new Mini-Ram, Edelbrock 58mm, Paxton s/c and the old TPI setup is now FOR SALE. Bargain if you buy it all.
Old Jun 18, 2003 | 01:25 PM
280Z28's Avatar
If only I had money for the TB and MiniRam.
Old Jun 18, 2003 | 01:31 PM
jdaniel's Avatar
1400.00 buys the Mini-ram, rails with AFR, and the 58mm Edelbrock. I'll pay shiping.
Old Jun 18, 2003 | 05:44 PM
Bobalos's Avatar
Wideband O2 <-- !!!
FWIW, You can do both, if you want to they are just not bolt on deals. buy an FJO or DIY WB & plug it up & use the Race software & it works. if you want to use DIS or CNP, you can use the FAST eDIST & plug it up.
BW
Old Jun 18, 2003 | 11:46 PM
CrazyHawaiian's Avatar
Car: too many ...
I say just spend the $900 or so dollars for the Commander 950, drive it around for a week letting it tune itself (its really not that hard), and enjoy the benifits of EFI. You went this far. Cant give up now!!
Old Jun 23, 2003 | 11:49 AM
jdaniel's Avatar
Back on board. I just ordered the FAST unit from TCI. I'll let you know how it works.
Old Jun 23, 2003 | 01:26 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I saw someone on ebay just sold one complete with WB o2 and 91-92 TPI type harness adapter for $1500, how much was yours and did you get a WB O2?
Old Jun 23, 2003 | 03:57 PM
jdaniel's Avatar
I'ma dealer for TCI so I got it at cost with the 02 sensor.
Old Jun 23, 2003 | 10:00 PM
StocRoc's Avatar
Can someone direct me to a website that sells the FAST system for our cars, or just tell me how much they usually sell for new. Thanks
Old Jun 24, 2003 | 10:45 AM
jdaniel's Avatar
Go to www.tciauto.com then scroll down to the bottom of th page and you'll see FAST.
Old Jul 7, 2003 | 01:50 AM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
I'm missing something here. With the com.950 you loose you speedo?
Old Jul 8, 2003 | 01:59 AM
Car: too many ...
The commander 950 does not support VSS. 90-92 Cars use VSS instead of a cable for the speedo. You might be able to get around this with a converter box and rewiring the VSS straight from the tranny to the guages (skipping the ECM). Not really sure. Call Holley and see what they say.
Old Jul 8, 2003 | 08:48 AM
Bobalos's Avatar
or try http://www.chevytalk.org/threads/pos...t=&Board=UBB12 Doug can answer your questions.
BW
seiplentz
Aug 19, 2019 06:02 PM
RedLeader289
May 28, 2019 01:47 PM
ULTM8Z
Oct 2, 2015 01:25 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
