super ram with boost?
Old Jun 21, 2003 | 06:05 PM
j91z28d1's Avatar
ok I've got a super ram just picked up and was wondering if I should sell it and get a min ram or the new holley.
I have a procharger making 15# of boost and i've never seen a test on with was better for boost.
oh yea the super ram is ported and this is a street car almost daily driven.
Old Jun 22, 2003 | 11:40 AM
j91z28d1's Avatar
nobodys every seen any dyno tests on witch is better
Old Jun 27, 2003 | 06:27 AM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
I have a Superram. I've use natually aspirated and now with my Vortech. You lose some bottom end power, but makes up for it on the top in a big way.
I E-mailed you a comparison test I found on somebodys site. I tried to post it here but I could not get it to work.
Old Jun 27, 2003 | 12:33 PM
j91z28d1's Avatar
nice car
reading your sig, it looks like i'm building the same car just a z28
but i'm starting with a 400 block and a d1procharger but samething really. i even have the same cam from before the blower. it seemed to like the blower when i had it on last time with the stock intake. i haven't tryed the superram yet i'm wating to get the 400 built
i got your e-mail thanks
are those n\a tests or under boost. i didn't see it anywere.
because i was thinking of building a 377 out of the 400. this d1 seems to love rpm and thinking 7000 rpm is close to the max impler speed to no pully change so it wouldn't spin the hell out of it just driving around town. like i would if if i pullyed it to max impeler speed at 5500.
i was just trying to see if anyone knew how a super ram would hurt power that for up to.
just trying to be diff than everybody else, i guess. but a blown solid roller 377 shifted at about 6800 would sound bad as hell
i may just build a 406 after all
oh yea are the times in your sig before the blower
Old Jun 27, 2003 | 11:00 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
just installed my super ram for the first time
I think it would look great on.....
on....
FIRE!!!
Old Jun 28, 2003 | 12:31 AM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
When we had our last central coast meet, there was a guy there Jeff(he posts on here sometimes) with a 383 with superram, and a vortech blower(might have been ATI cant really remember) He said that they loved eachother. His car is crazy fast!
Brian
Old Jun 29, 2003 | 11:21 PM
BLWR PWR's Avatar
Car: 89 IROC
Engine: Built 383, Vortech SC
Transmission: Pro-Built 700R4
Axle/Gears: Dana 44, True Trac, 3.54
That is my car that Brian mentioned. I have a new combo with a 383, Superram, S-trim, Trickflows, 218/224,520/520, and all the supporting goodies. A Pro Built 700R4 and Dana 44 with 3.54s. I am still learning how to drive this new set up. If there is ANY torque loss down low you cant notice it. From 3000m on up it flat out hauls the mail. I now have an EXTREME traction problem. With worn out drag radials, if I punch it from a stop I get severe tire spin thruogh second to the point of getting out of the throttle cause it is no use. I just got new drag radials this weekend. I run those on the street cause any other street tire was useless(for traction). And yes i have subframes and lca's. Next step is a adjustable torque arm and reloc. brackets. Anyway, from 3500 it just takes off and keeps pulling. Finally back out at 6200 and about110+ in third, it gets scary! The 383 loves a superram, add a blower for the icing on the cake. Also passed Cal. smog clean as a whistle. Oh yea, the old 350 with zz9, trickflows, long tube Acell runners ran 12.5 at 111. (with blower). I havnt been to the track yet with the new motor. It should rock! Jeff
Old Jun 30, 2003 | 02:33 AM
j91z28d1's Avatar
how much boost were you running on the old set up and did you notice any loss of boost with the better intake.
thanks and your car sound like a blast to drive
Old Jun 30, 2003 | 10:19 PM
BLWR PWR's Avatar
Car: 89 IROC
The old setup was 6lbs(observed on the gauge). With the new set up I am only seeing 31/2 to 4lbs. non - intercooled. Once I get the hang of the new set up and some more traction aids I'll play with the pulleys for a little more boost.
Old Jun 30, 2003 | 10:35 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I dont know if you have a pic of it to show it off or not Jeff. Here is one I took at Dennys, hope you dont mind(if for whatever reason you do, let me know and I yank it).
Brian
Old Jun 30, 2003 | 10:36 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I have a video of it also. If anyone/Jeff wants me to post it.
Brian
Old Jun 30, 2003 | 11:39 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I'll let you guys know how a 383 superram 9psi boost runs soon, waiting for a new transmission from Pro-built and some tuning. Pictures are at my website, enjoy....
/N.
Old Jul 2, 2003 | 02:56 AM
j91z28d1's Avatar
thanks guys i may try the super ram out first before i sell it.
i guess it could flow good enough
Old Mar 3, 2004 | 06:36 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Sorry to bring this post back from the grave, but I'm thinking of a SR swap onto my LT1 and I'm interested in any pics, vids, and comments you have on your SR setups.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
no green
Jan 9, 2016 09:22 PM
mfp189
Sep 27, 2015 09:25 AM
Dragonsys
Sep 25, 2015 03:51 PM
