ATI D1-SC Belt Problems
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
I can't seem to get the belt on correctly. No matter which way i route it, its either too short or too long and can't get enough tension on it. Can someone show me how they have it routed with a picture illustrating your routings. I'm think they sent me the wrong belt cause i follow their instructions there is way too much slack. I have Gates K208067. Can some else tell me what pulley they have and belt their kit came with.
Car: 1992 B4C 1LE
both passes of the belt will pass in between the two idlers. with only the "back" of the belts contacting the idlers. like this
Engine: Inline 6
Axle/Gears: 3.13
Ok guys, I'm seriously about to ditch this thing to the nearest hill. I have since received a 4.25" pulley and a K0800660 belt and it still doesn't work. I can't get enought tension on this pulley
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
bad news man. they gave you the wrong belt. It's routed correctly but they goofed.:lala: If I were you i'd get some string or rope and go around the pulleys the same way you have the belt, measure the distance, and get a belt about a 1/4" smaller than your measurement. Thats what I did with my 4" pulley and I use a napa 62x1/8" belt. I have to jump it onto the pulley and it slips a bit on the top end but at least it works.
Just for the record ATI sent me the wrong belt 3x before I went and measured.
Engine: Inline 6
Axle/Gears: 3.13
Finally i got a belt to work with it. I ended up using a K080653 Belt and it worked. Whew! Thank ***, almost ready to fire her up.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
db057
Aug 11, 2015 10:11 PM
