Tnt
Old Aug 14, 2003 | 12:53 AM
bizkitiroc's Avatar
Tnt
the nitrous kit I'm looking at is made by them. Are they a good reliable company? also, the kit is coming off an LS1. would there be any problems putting it on a 350 TBI?
Old Aug 14, 2003 | 04:36 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yes and yes
Old Aug 14, 2003 | 11:18 AM
bizkitiroc's Avatar
what kind of problems? I'm not exactly sure if the kit was made for the LS1 only, but its the main reason why I am hesitant about buying it
Old Aug 14, 2003 | 11:25 AM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
If the kit is a fogger plate type right behind the throttle body, It wont work at all. the LS1 TB is far different than the tb used on the L98 and Lt1.
LS1: O
L98,Lt1: oo
Old Aug 14, 2003 | 11:33 AM
bizkitiroc's Avatar
man that sucks , could I drill that out to where it would fit without causing any problems?
Old Aug 14, 2003 | 11:45 AM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
no..
Old Aug 14, 2003 | 12:15 PM
bizkitiroc's Avatar
what about getting a spacer to go under the carb and hooking the nozzles up to that?
Man, if nothing works I may just have to pass up on the deal
Old Aug 14, 2003 | 02:08 PM
TexasLT1's Avatar
Car: '92 RS
about the only thing you could do is get the kit, ditch the LS1 spray bar or nozzle or whatever it uses, and buy the correct spray bar that you need.
Old Aug 14, 2003 | 02:22 PM
bizkitiroc's Avatar
ok thanks texas. you have any idea how much one of those would cost??
Old Aug 14, 2003 | 07:25 PM
TexasLT1's Avatar
Car: '92 RS
no clue, you'll just have to check the kit and see if it can first be replaced, then find something that will work for your application. I would advise against getting the LS1 kit and just get the right one for your application.
OUTATIME GTA
Northern California
Nov 30, 2008 09:57 AM
83 Crossfire TA
Mid-Atlantic Region
Apr 25, 2008 08:06 AM
FactoryFreak
Mar 9, 2007 07:12 PM
FactoryFreak
May 15, 2004 09:52 AM
LETHALRACER
Oct 25, 2002 07:46 PM
