Torque specs and crank specs
Old Jan 22, 2004 | 12:14 AM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
I need the torque specs for the main and rod bolts for a 355. Also, i need the clearneces for rods and mains, so i can test them with plastic gauge. crank and pistons go in tomorrow. I also wil take supercharger cam recommendations,.. see my sig. I'll be running around 8 or 8.5:1 compression with the setup and 8-12 lbs intercoold boost. thanks
Old Jan 22, 2004 | 06:12 AM
ede's Avatar
ede
you're building an engine, a power adder engine even, and you don't have a manaul or any measuring tools. try 40 ft/lbs on the rods and 65 ft/lbs on the mains. don't have a manual here and the clearances are differant for each main, but around .0015 to .0025 is about right. for the rods try .002 to .0035. really ought to look in a manual and not trust some dumbass on the net.
plastigage is a joke and i wouldn't trust it. use mics, snap gage, and bore gage to check clearances.
Old Jan 22, 2004 | 07:24 AM
Car: 1987 GTA
true,.. my freind built alot back in the day, and he deosn't remember the specs and he can't find manuals,.. hoping someone had one. thanks
Old Jan 22, 2004 | 01:00 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
What fasteners are you using? I used ARP hardware through out. The rod bolts called for 65 ft/lbs. But the best way for installing rod bolts according to them and my machinist is to measure the bolt stretch. Requires another tool I didn't want to buy!!! I just torqued with good 'ole torque wrench.
As for mains, I did 75 on the inner studs and 65 on the outer studs. 4 bolts mains in you didn't already figure that out!!
I am running a slightly looser main clearance because of the fact I hope to 'charge it one day. Rods, I am running about what was posted by ede.
You can find stock specs in just about any shop manual for a third gen. And many of the DIY engine books have lots of specs for stock, mild performance, race. They are of course just general specs, but they will get you in the ballpark.
I am running a Comp Cams blower cam. I have a bit more CR than what you plan to have, but even without the blower, my engine runs pretty strong. Makes me really wish I had the money to buy a blower!!
Old Jan 22, 2004 | 04:57 PM
kevinc's Avatar
Car: 1982 Z28
I have one, probably several people have them, but I'm not really clear on why I should blow a lot of time typing up torque and clearance specs for you.
http://www.helminc.com/ has everything you need, go have fun.
Old Jan 22, 2004 | 06:45 PM
Car: 1987 GTA
92 zzz28,
what cam are you running?
I am lookign for a cam kit with springs and lifters.
i am also looking at a trick flow cam to match my heads,.. it is 228/234 480/494, but the lsa is 110, i need a 114 for the blower. I here there are good XE blower cams that will meet what i need,.. but i forget which ones they were. thanks for any help
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MM2Robinson
Oct 1, 2017 09:16 AM
customblackbird
Oct 1, 2015 04:30 PM
angel2794
Sep 8, 2015 06:22 PM
Formula_88AE
Sep 3, 2015 01:47 PM
