Who makes the best N2O kit?
Old Dec 28, 2003 | 01:40 PM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
I know this topic may belong in the product review section, but hopefully I won't get locked for bringing it to the experts. I have finally decided on a Nitrous setup. I want to run a 100 shot. I will start with the lowest setting when I get the kit and work up to the 100 tuning as I go. My motor is solid, uses no oil, well except the little valve guide related puff on startup. I will also be replacing the stock fuel pump. Who makes the best kit?
I will also be adding a fuel pressure, N2O and air/fuel ratio gauges so I can keep an eye on a few vitals.
-NOS
-NX
-CompuCar
I found out that ZEX makes a dry system for the third gen, are they just a ***** company or what?
Please be gentle I'm new to the nitrous area.
Thanks for any advice,
Jason
Old Dec 28, 2003 | 09:45 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
NOS, NX, Nitrous Works, CompuCar, TNT ...all make good kits that will suite your needs. I don't know about ZEX though, nor would I ever go with a dry kit.
Old Dec 29, 2003 | 07:31 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I would stay away from Nitrous works. Their jets are on the small side. I've seen someone have to jet a 225 shot to see less than 150 at the wheels. NOS or NX.
Old Dec 29, 2003 | 07:06 PM
J's86ROC's Avatar
Car: 1986 IROC-Z
Thanks for the replies.
Jason
Old Dec 30, 2003 | 03:01 AM
Kandied91z's Avatar
i like my nos....i'd rather have nx. they both are the same price in the end although nx uses a better valve for their main setup. some of newer nos pieces are just as nice. either one is a good choice. personally which ever is cheaper!
i think i spent more on the safety pieces then anything, be prepared if you want to be safe....live dangerous and have alot of power for very cheap.
Old Dec 30, 2003 | 02:03 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
I have used both NX and NOS and I like the NX kits better. They are just better quality in my opion.
Old Dec 31, 2003 | 01:39 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
hey guys, i looked into the NX kits and they have some 4bbl kits. they seem to have Holley 4-BBL kits and then Q-JET kits. which one works with an edlebrock carb?
Old Dec 31, 2003 | 02:14 PM
Car: '89 IROC-Z
I find that very odd and I'd more than likely blame it on his motor combo rather than the jets ...Plus I'm 90% sure Nitrous Works rates their kits at the flywheel, not rear wheels so their jets for the 150 shot isn't going to give you 150rwhp. I have however heard the opposite about Compucar. Apparently they rate their kits at rear-wheel HP.
Old Dec 31, 2003 | 08:24 PM
J's86ROC's Avatar
Car: 1986 IROC-Z
Trans_Am_88,
Your Edelbrock carb should be a sqare bore, so the Holley kit would be the one you need.
Old Jan 5, 2004 | 10:16 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Nx also rates the power at the wheels.
It probably was a tuning issue, but if I'm spending over $500 on any part of my car, I don't like "probablies" or maybe's.
Old Jan 5, 2004 | 11:24 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
I think a lot of people dont realize that spraying with 150 horsepower jets on a kit rated at the rear wheels is the equivelent of running 190 horsepower jetting on a kit rated at the flywheel.
Old Jan 5, 2004 | 11:28 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i personally think "horsepower" is a stupid way to rate a kit to begin with.... but we're kinda stuck with it now.
Old Jan 5, 2004 | 01:37 PM
I was going to say that as well. There should be a universal measurement. It works pretty well when a manufacturer says:
"on a 2002 Camaro z28 this kit will add an additional 100 horsepower at the wheels", because they know the intake, camshaft specs, displacement, drivetrain, etc. However, its impossible for a carb plate kit for small block chevys to advertise gains in horsepower when every motor it will be going on will be different.
Old Jan 5, 2004 | 02:08 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
my buddy has had nothing but good things to say about his Nitrous Works kit and i have had good results with Nitrous Express. it's really more of who's sticker you want to run when you go to collect Contingency money (if applicable).
Old Jan 6, 2004 | 10:11 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Old Jan 9, 2004 | 12:55 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
That depends on which Edelbrock carb you have.
Some are based on the Carter AFB design and that is a square bore style like most Holleys.
Some are based on the Rochester Quadrajet design and that would be a spread bore.
Old Jan 10, 2004 | 05:24 PM
usa1racing's Avatar
88IROC350TPI, please e-mail me, usa1racing@hotmail.com. I have a few questions about your car. Thanks.
Old Jan 10, 2004 | 05:31 PM
usa1racing's Avatar
Old Jan 22, 2004 | 08:10 PM
Ericritter7407's Avatar
Car: 88 Camaro Iroc-Z
Engine: 350 carbed bored 30 over
im thinking about getting a NOS kit soon what do you reccommend for a 88 Iroc, 4 barrel 350
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Terrell351
Jun 13, 2021 01:13 PM
toronto formula
Nov 10, 2015 06:17 AM
Mickeyruder
Sep 2, 2015 02:45 PM
fasteddi
Sep 2, 2015 10:29 AM
