Where can I get a pulley?
Old Mar 3, 2004 | 06:41 AM
Blown87's Avatar
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
I have a Paxton SN2000 supercharger. It is the set up that has three V-belts. I am looking for either a crank pulley or a pulley for the compressor that will increase boost to about 10-11 PSI. Can anyone help me locate one (either new or used)?
Old Mar 3, 2004 | 06:10 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Jim,
When I owned my Paxton, I found Auto Specialties Performance could fab a three-belt pulley. I had to send mine in to use as a pattern but they can make just about any diameter you need. That was about four years ago, but I paid $95.
http://www.aspracing.com/frame.htm
Just make sure you don't exceed the blower redline, about 37,500.
Old Mar 4, 2004 | 08:21 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
paradise wheel has them #1-760-740-0954 also i found a good oilcooler for them at www.jcperformance.com. paradise also can install vr-4 upgrade you will get 12-15psi
Old Mar 4, 2004 | 09:17 AM
SharpZ28's Avatar
Car: 92 Z28 Camaro
Engine: 350 TPI : Supercharged
Transmission: TH700R4
Hey Antoine, do you know if Paradise Wheels has an e-mail? Also, if you did the Vr-4 impeller upgrade, what do they charge to do this? Thanks for any info.
Old Mar 4, 2004 | 05:51 PM
Blown87's Avatar
Car: 87 Z-28
Axle/Gears: 3:73
Willie,
It is good to hear from you. Thanks for the information. When you replaced the pulley on your Paxton, how much boost did you pick up?
Antoine, I went to Paradise Wheels web site but could not locate the part number that you referenced. I called them and they had the pulley in stock. So, I bought it and it is now on its way! I bought the 3" pulley. The pulley on the unit currently is 3 1/4".
Old Mar 4, 2004 | 06:36 PM
SharpZ28's Avatar
Car: 92 Z28 Camaro
Blown87, how do you get Paradise Wheels website? I have tried searching and can't find it. Thanks
Old Mar 4, 2004 | 06:47 PM
Blown87's Avatar
Car: 87 Z-28
Axle/Gears: 3:73
www.paradisewheelsinc.com
Old Mar 4, 2004 | 09:01 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
Willie,
you just saved my @ss man. i have this B&M blower that i cannot find pullies for. im frantic and this was the 1st post i came to and already got the problem solved im going to contact that place that can fab pullies... thanks again man :hail:
Old Mar 5, 2004 | 07:50 AM
Blown87's Avatar
Car: 87 Z-28
Axle/Gears: 3:73
Originally posted by Willie
Jim,
I believe the equation for calculating impeller speed is: (crank diameter/compressor diameter)*RPM*blower ratio=impeller speed. With the ratio of the SN being 4.44:1
If this is correct, then I have a max engine speed of 4400?
(5.75/3)*4400*4.44=37317
That would mean that the max engine speed as the blower came from the factory was about 4700 RPM?
(5.75/3.25)*4700*4.44=36920
I think I am doing something wrong, could anyone offer some assistance?
Old Mar 5, 2004 | 12:02 PM
antoine's Avatar
i will upgrade my paxton to vr-4 in two weeks just got my smc injection kit so will upgrade soon.also vr-4 kit they will sale you for 500 dollars.jcperformance has the best oil coller 350 dollars.
Old Mar 5, 2004 | 12:49 PM
SharpZ28's Avatar
Car: 92 Z28 Camaro
I just spoke to Craig from Paradise Wheels, and the impeller upgrade is good for 1 to 2 pounds more boost. It is $200 to purchase and have them install at any time or $100 at time of rebuild.
Old Mar 5, 2004 | 03:26 PM
Willie's Avatar
Oops. Sorry I haven't been back here.... need to do some catching up.
Actually, I had a LARGER blower pulley fabbed. Because I was reaching blower rpm way before engine rpm, I decided to slow the blower down so I could rev the engine to its redline -- big mistake. I lost so much boost that the custom fabbed $95 pulley became a very expensive paperweight.
Glad to help!
I believe the equation for calculating impeller speed is....
Jim, your calcs are correct. With the stock pullies, impeller redline is reached at ~4,700 engine rpm. My engine is built to run to at least 6,000. Now can you see why I decided to have a pulley made? Yes, I was able to run to 6,000 engine rpm without exceeding impeller redline, but lost boost. So if you decide to speed up your impeller rpm's, you'll decrease your usable engine rpm's.... You just can't win with such a low impeller redline. This was the determining factor in selling my Paxton years ago and going with ATI. The D1SC that replaced it has a 60,000 to 65,000 rpm redline. Without performing any calcs, you can see that there's plenty of room to grow with such a unit. Today with my F1 and it's 70,000 rpm redline, I've got even more room.
I'm not familiar with this "VR-4" impeller but it produces the same as Paxton's old high performance impeller. With it, mine made ten pounds. With the stocker, I was seeing eight.
Willie
Old Mar 6, 2004 | 12:08 AM
antoine's Avatar
willie,the vr-4 was the first supercharger to put out 12-15psi of boost was race only blower
Old Mar 9, 2004 | 10:51 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
I dont think this place has anything for your paxton but anyone with a supercharged gm 3800 like mine can get one here
www.pulleyboys.com
Old Mar 11, 2004 | 06:14 PM
Blown87's Avatar
Car: 87 Z-28
Axle/Gears: 3:73
I just installed the pulley from paradise wheels. Even though I can now only rev the engine to about 4900 (which still exceeds the compresser redline) I got 11 PSI of boost. The car pulls alot harder and I am pleased with the results.
Thanks to all for the help.
Old Mar 12, 2004 | 08:56 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
what there is only "weak stock" and "too much" available? nothing in between?
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
evilstuie
Sep 24, 2015 02:31 AM
