turbo'd 383 questions?
Old Mar 4, 2004 | 09:01 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
Hey guys im dead on wantin to build a turbo'd 383 with the Holley stealth ram injection. how hard is it goin to be to obtain 6-800hp with that set up? also the bottem end is goin to be fully fordge parts, heads im not sure of something from AFR probably, cam i have no clue. probably goin to see about gettin a partial turbo kit from BBSdesigns and make my own FMIC or see if some one can custom make one for me. then top it off with the Holley stealth ram fuel injection set up. of chorse the motor will be at 8.5to1 compresson.
i just need some answers and idea's and help basiclly. if so thanx guys.
Old Mar 4, 2004 | 09:16 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
800HP is a lot of spending... have you looked at head/cam/intake kits? 383 kits? they offer kits with a wide range of HP. all ya gotta do is get a kit and fab on the turbos
Old Mar 4, 2004 | 09:19 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
a nice bottom fordged bottome end 383 some afrs a hsr and a single pt88 would be a nice setup.
Now the qestion is are you talking FWHP or RWHP
what kinda car you talking? Street Driven beast or More of a Strip Car and some weekend light to light action,auto-x , etc..
Old Mar 4, 2004 | 09:24 PM
jon_volk's Avatar
longblock.....http://www.speedomotive.com/725_h.htm
then add another 2000-3000 in good parts if you use all new stuff and do it yourself.
Old Mar 4, 2004 | 09:49 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
well the car would probably be a streetbeast but also will get its fair share of track use and also a show car. once i restore the car it will be mainly show/strip car. hp will probably be fwhp so ill still have a crap load of hp to the wheels anyway.
but heres the short block ill be using, it also has options to upgrade the crank and rods and other parts that they put in the short block short block and heres the turbo kit ill be lookin at. im goin to get either a partial kit or a complete kit but not use the intake elbows since i plan on making or gettin a FMIC and plumb the system my way. turbo kit
Old Mar 5, 2004 | 06:39 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
befor you buy that short block Id make sure you specify you want around 9:1 comp. It says thats a 13:1 motor. so Im guessing it has dome pistons.
The rest looks good.
Old Mar 5, 2004 | 08:48 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i called the company awhile ago and asked them about puttin a blower on it (at that time iwanted a blower but now i want a turbo) and he said that they can get the compression set to alomst anything i want, so he can get it down to 8.0 to 1 if i wanted but i think 8.5 to 1 is good for a boosted motor.
Old Mar 7, 2004 | 06:18 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
what kinda heads, cam , and is the holley stealth ram a good choice for a turbo set up? i wont use tpi since it dies out at 4400rpm. also with the holley stealth ram, can i just get the wiring harness from Painless and it should all bolt up and wire up the same right? my car is carbed right now so goin from that to turbo'd injected motor will be a big leap on this car.
lt1z350
Aug 28, 2015 05:57 AM
crazynights
Aug 21, 2015 06:53 AM
PestilenceIV
Aug 20, 2015 03:32 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
