problem I now have with sumped gas tank
Old Mar 11, 2004 | 07:38 PM
superirocz's Avatar
Start tuning my FAST on my turbo iroc and car is starving for fuel look at this.
I figured there are a few guys in this forum who have sumped there tank. I had a sump welded on my factory gas tank. I was advised to put some sealent to protect agaist possible rust. I call Eastwood co very reputable or so I think. They sell me two cans of gas tank sealent for like $50 I follow the instructions like they say and let the tank air out for a few weeks just to be safe. Well car is starving for fuel so I check my aeromotive ss filter before the pump and what do you know its full of white film looks like sheets of paper. The car has sat for almost a year since I sumped the tank. Not sure how to get the rest of this junk out of my tank? The only thing I can think of is a hose into the gas filler and leave the 3/8 holes open in the sump and just let it run for a few hours. Good thing is none of it got past the ss filter and into my pump or aeromotive paper filter after the pump. I'am hoping this gunk is done peeling and has just been sitting in the gas tank from when I installed the tank last spring, any suggestion.
I will be calling Eastwood tommorow not very optimistic about that.
By the way the car is up and runing good and I have someone helping me tune the car via the net and using the dataloger on the FAST ecm or atleast we will proceed ounce I fix my gas tank problem
Old Mar 11, 2004 | 09:08 PM
biggtime's Avatar
I had a buddy use that same **** on his harley tanks. Same problem you had, it peeled of in sheets. We were able to get it all out with needle nose pliers.
Old Mar 11, 2004 | 09:52 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Whatcha complaining about? It "sealed" your fuel system didn't it??
Thanks for the unintended heads up.. BW
Old Mar 11, 2004 | 10:07 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Next time tig weld the sump and you wont need sealant.
Old Mar 11, 2004 | 10:22 PM
superirocz's Avatar
Well it looks like a new tank may be in order
Old Mar 11, 2004 | 11:10 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i had my sump TIG'd and i haven't had to seal anything at all....my filter still looks brand new as well.
Old Mar 12, 2004 | 12:00 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I have a spair tank if you need it. Dono if its feesable to ship it or not. of if your close enough to Ohio to pick it up. But its FREE if you like.
Old Mar 12, 2004 | 01:13 PM
superirocz's Avatar
If its free I will take it. My zip is 16803 UPS will ship it just clean it with saop water so it dosn't reak of gas for ups. I live in state college central PA
Old Mar 12, 2004 | 01:39 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
e-mail me with your Addy and stuff at chris@cecoatings.com
I'l try to Drop it outa the parts car 2nite or2morrow and flush it out. and I'll try and find some boxes to wrap it up. We have some large ones at work that will do the job.
any idea what a tank weighs so I can get a shipping quote for ya?
Old Mar 12, 2004 | 02:02 PM
xpndbl3's Avatar
Car: 1984 Z28
tank weighs around 20 pounds from what i can tell when i had mine out empty
Old Mar 15, 2004 | 03:40 AM
83 Crossfire TA's Avatar
you'll get charged for it being oversized, the weight won't be an issue. You could probably just tape over any parts that come off and just stick a label on it, I doubt that wrapping it will make any difference...
As far as welding procedure… MIG/TIG won't make a difference. It's more about how you do it. I was having a problem with pinhole leaks at the beginning of welds and near where I tack welded it and it turned out the problem was the way some old timer showed me how to make where 2 welds come together look pretty. I used to start a little ways away and backtrack over the original weld. Turns out that you won't get a leak if you start ontop of the original weld.
And I was just thinking that if I had a spare tank sitting around… I guess I missed out.
Old Mar 15, 2004 | 06:38 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
bump.. I didnt get a change to take the tranny out saterday. Ended up building a crate to ship a th350 to NJ. and coatings some parts.
I will deff have it out this weekend for you. Working midnights sucks sometimes. if your in a rush I can have my buddy ben swing over and pull it for me.
LMK.
Mark if you looking for one Theres a junk yard here with a few dozen 3rdgens. I can always call and get a price. The guy hooks me up with decent deals cuz Ive bought a complete parts car form him befor. and Send everyone his way.
Old Mar 15, 2004 | 02:46 PM
I'm looking but not looking that hard. I figure that by the time I get around to actually doing something with it I'll have one...
thanks
chazman
Aug 28, 2018 03:25 PM
Infested
May 22, 2018 11:56 PM
mustangman65_79
Sep 1, 2015 03:51 PM
chazman
Aug 22, 2015 02:01 PM
AkDrifted
Aug 17, 2015 07:45 PM
