Does anyone make a supercharger for an 85 IROC
Old Apr 18, 2004 | 11:25 AM
iroc_cragg's Avatar
I havnt been able to find a supercharger kit for and 85'. Ive heard that paxton makes a kit for the 85 but I havnt been able to find it on the web. Anyone know. Thanks
Old Apr 18, 2004 | 03:16 PM
benroc's Avatar
Car: 89 Iroc , BMW M3
Engine: 383 with D:1SC,hooker long tubes,197 JEGS heads,superram,hot cam.
Transmission: 700 aut with 2600 vigilante
They have for TPI camaros:
http://proficientperformance.com/Mer...o_firebird_tpi
Old Apr 19, 2004 | 02:29 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Paxton used to make a kit - not sure if they do anymore.
Old Apr 19, 2004 | 03:24 PM
Guido's Avatar
Car: 2000 Trans Am
Thats not a link for 85 TPI cars. Maybe you should read the links before you post them?
Old Apr 19, 2004 | 04:07 PM
benroc's Avatar
Not only I`ve read it but I`ve got a Procharger from them
and if it works for a TPI it works for all TPI`s.
Maybe you should think when you read
Old Apr 19, 2004 | 04:09 PM
benroc's Avatar
and if it works for a TPI it works for all TPI`s with maybe a litle
modification.
Old Apr 19, 2004 | 04:13 PM
benroc's Avatar
Ou, maybe I should get banned for telling the truth to a moderator twice
Old Apr 19, 2004 | 04:16 PM
Guido's Avatar
Car: 2000 Trans Am
*sigh* I cannot believe I actually have to spell this out.
Alright benroc. Thirdgen 101:
85-87 TPI thirdgens, were equipped with a v-belt accessory drive system.
88-92 TPI thirdgens, were equipped with a serpentine type accessory drive system.
That being the case, there are supercharger KITS designed to work with both types of belt drives. The kits for 88-92 are more plentiful. Paxton USED to manufactur a kit that worked with the 85-87 type v-belt drive but they discontinued that line.
That being said, if someone wants to convert from the earlier v-belt to the later serpentine setup, they can do. Its time and money consuming as the power steering, water pump, alternator and air conditioner all need to be changed. Then, you can use one of the 88-92 kits on the 85-87 model year setups.
I have an 86 IROC and I have BEEN down this road. I converted to the later style in the past because I went from one of the old paxton kits (which is junk I might add) to the later style so I could put a Vortech supercharger on my car.
Make any sense now?
Old Apr 19, 2004 | 04:30 PM
benroc's Avatar
It makes sense , you did to have a better set up let him decide
if he wants to do it
Old Apr 19, 2004 | 10:00 PM
iamjeff's Avatar
what is the prob with the old paxton kit? bad reliability? bad performance? bad fit/finish?
-jeff
Old Apr 20, 2004 | 06:47 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
well dont just show him a link to the blower he already knows exists, he is looking for the one you didnt list. give some options, he knows there are kits for other years thats why he made the post.
here is a guy looking for the same thing:
https://www.thirdgen.org/techbb2/sho...hreadid=236041
toronto formula
Nov 10, 2015 06:17 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
