Project GIT-R-DONE
Old May 26, 2004 | 05:00 PM
90ludepunkfl's Avatar
Project GIT-R-DONE
Ok project GIT-R-Done is just in its infant stages.
car: Camaro Rs 3.1 v6
Just a parts/things to do list bleh...when I finally get everything together I will take pictures and make a writeup etc...
setup: 2 t25 turbos
2 oil feed/return lines
2 small intercoolers
2 Bov
X 180 mandrel bends
2 chopped up stock manifolds w/
flanges welded up (i need a
set)
2 downpipes
Oil pan (so I don't have to go
with out a car)
Gauges
Fmu
24# injectors
Holley in-tank fuel pump
If anyone happens to have any of this stuff and willing to sell it (remember I am trying to be as cheap as possible). Send me a pm I check here every day!
Old May 26, 2004 | 05:48 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
let us know when you actually GIT-R-DONE
Old May 26, 2004 | 05:50 PM
Will do I am just figuring out what to use right now (eh actually what I can get for cheap that will work) This project isn't meant to go fast or look pretty so if your looking for either you will have to look some where else. I figure with some luck I can have this project done by Christmas.
Old May 26, 2004 | 11:54 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Do you already have the turbos?
If not I would not get t25s........if your looking for cheap stock turbos get 2 14b's from a 90-94 DSM with a manual tranny.
They are better...and probably just as cheap.
Old May 27, 2004 | 06:50 AM
Nah I don't have the turbos yet......I was thinking 14b's but it all depends on what I can get my hands on. If I can get them I will, but if I can't then i'll just go with the t25's.
Old May 27, 2004 | 08:09 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
24 pph injectors will not work without a rechip.. I don't see any prom burning on that list.
Old May 28, 2004 | 06:59 AM
From what I was told 24# injectors were the biggest you could go without rechipping......I will have to look further into this. Thanks.
Old May 28, 2004 | 12:09 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Whomever told you that flat out lied. I've got a single 16g pushing anywhere from 10-15psi (right now, I really got to get that nailed down!) with 22pph, and with no chip, it runs MASSIVELY rich.
Old May 28, 2004 | 02:30 PM
TechSmurf's Avatar
Engine: LS1, Scrap
The person who told you this in the previous thread (89JYturbo) changed their opinion in that thread when I mentioned the stock injector size.. perhaps you should check your threads more often... this is why we try to stick to one thread on a topic as long as possible.
Originally posted by 89JYturbo
I don't think there would be a need to reprogram the ECM. The 24# injectors are only slightly larger than stock and should pose no drivabilty problems on the stock chip.
Originally posted by TechSmurf
Slightly?? Uhm... they're 60% larger. Stock 3.1 injectors are a measly 15#..
Wow, that is a big difference. I didn't reaize the stock injectors were that small. In my TT L98 I went from the stock 19# units to 24# units with no problems- I just lowered the FP at idle to 38psi. Maybe 19# injectors would be the better choice.
Old May 28, 2004 | 06:22 PM
Doward's Avatar
In that case, I take back what i said - the person that told you that, was mis-informed, and in the end, correct.
But 19s are still too big without reprogramming the chip...
Old May 28, 2004 | 07:42 PM
Oops bleh guess i'll have to look in to rechipping.
Old May 28, 2004 | 08:25 PM
Damon's Avatar
Why change the injectors at all with an FMU? Unless you're going well beyond what stock sized injectors can handle HP-wise, the FMU's job is basically doing exactly what you're after- compensating for boost by adding more fuel (via proprtionately increased fuel pressure under boost).
I'm guessing you're keeping boost modest given the basically stock engine you're bolting the turbos onto so I would think an FMU alone would get the job done for you, no chip reburn required. No?
Old May 28, 2004 | 11:12 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
I was thinking the same thing. I would think an FMU alone should do the trick for 5 or 6 psi boost. Sorry if I complicated things by suggesting those larger injectors. I should have looked into that a bit more before I responded.
Like I said in your other thread, just make sure your fuel pump is up to the task. Asking it to pump a larger volume of fuel at very high pressure will give it a good work-out.
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
Vincent135
Sep 28, 2015 10:50 PM
