Oil out dipstick tube with blower
Old May 28, 2004 | 05:07 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Howdy. Just finishing putting a 3rd hand Vortech on my L98. When I get into boost, I get oil blowing out of my dipstick tube. Doesn't appear that I have the "puff of death" or anything like that.
There is a vent in one of the valve covers that connects to the intake or throttle body, which puts boost into the crank case - I don't have a check valve in the line. Could this be the source? If so, any suggestions on where to acquire a checkvalve for this larger size line?
Old May 29, 2004 | 02:22 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
You have one hard line from the right valve cover to the side of the TB.
That one must be replaced with an open filter and a plug at the TPI, or you can route the line to between the filter and blower.
On the driver side you have a hose going from the intake to the PCV-valve in the valve cover. If the PCV valve is good you can keep it. If it is bad you will boost the crankcase during WOT.
Old May 29, 2004 | 03:21 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yes what he said, no more PCV valve and no more vent line. Both must vent to atmosphere.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
z 28 jari
Sep 14, 2021 10:03 PM
gta892000
Aug 11, 2019 11:16 AM
BDR
Nov 7, 2015 03:05 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
