Common mistakes or problems....
Old Jul 27, 2004 | 11:36 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
that I could avoid when installing my direct port. Are there any? I would like for this to go as smoothly as possible.
Old Jul 27, 2004 | 12:07 PM
89305RS's Avatar
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
make it look nice!!! Nothing is better than a GREAT looking nitrous system.
Old Jul 28, 2004 | 05:57 AM
83 Crossfire TA's Avatar
I can think of something better... one that actually works. After you get past functioning, looking pretty is cool as long as you can get it without messing with the function.
Old Jul 28, 2004 | 11:16 AM
biggtime's Avatar
Translation:
"make it work nice!!! Nothing is better than a great working nitrous system"
Old Jul 28, 2004 | 11:22 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Looks? No one will see it.
Old Jul 28, 2004 | 02:16 PM
89305RS's Avatar
or hide it WTF ever make it look and work nice.
Old Jul 28, 2004 | 02:22 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
take your time and measure out the hardlines first.
its easy to get in "the groove" or in a rush, and foobar a line.
also, it goes without saying, use a good bender made for that size... "universal" benders suck.
Old Jul 30, 2004 | 07:40 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
i am guessing that it is a carbed setup, when i had my direct port on my car it worked great but the only problem i ever had was making sure the dumb thing didnt run lean either by the pump or the carb, its a little hard to find out after you have melted your comb. chambers that you were running lean, so my advice is to make sure you are dialed in then you should be happy
Old Jul 31, 2004 | 10:01 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
it's a fuel infected car and the n2o already has a separate fuel system that will pump cam 2. I don't think i'll run lean.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
FormulaEngland
Sep 30, 2015 01:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
