Need Intercooler That Will Support Serious Power Asap
Old Aug 25, 2004 | 06:59 PM
FireRed91Z28's Avatar
Car: 91 Z28
Engine: currently 350...BUILT 383 soon
Transmission: T56 w/4.10's
ok this is not as easy as it sounds...the intercooler must somehow fit my 91 Z28. im looking preferably for an air-air one and if they make twin hi-flows that i can set up the same as in Willie's post, but support my power range (1000fwhp) someone please tell me where i can get them.
if not, then i could do a frount mount set up but i need for it to fit in the front. i am currently removing all A/C related parts so i will be taking out the condenser infront of my radiator. from looks of it i dont have all that much room. what can i do??
Old Aug 27, 2004 | 08:13 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Need Intercooler That Will Support Serious Power Asap
right..
-- Joe
Old Aug 27, 2004 | 02:28 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
get a big one from ATI the ones they sell with the procharger.
Old Aug 27, 2004 | 10:42 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
How about spearco intercoolers?
Old Aug 28, 2004 | 12:24 AM
Car: 91 Z28
i was looking into spearco....but are there any certain/minimun size i need for it to be able to support 1000HP? if this is going to be a front mount it needs to be able to fit infront of my radiator...hopefully even have room so i can set up a fan behind it to help keep everything cool as i know im gonna have a hot car using a front mount intercooler.
Old Aug 28, 2004 | 09:00 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Just go to their website and see if there is anything that catch's your attention.http://www.turboneticsinc.com/. Or give them a call and see what they say.
Old Aug 29, 2004 | 12:12 AM
Car: 91 Z28
alright think i found one...gotta take off my bumper and do some measurements. its 3.5"w x 20.8"L x 10.5"H.
Old Aug 29, 2004 | 10:03 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
There is NO Way that 3 1/2" thick intercooler is going to fit between in front of the Radiator. I have a 3"X31"X12" and the only way to go bigger is you could probably go 15" or 16" tall. I to got rid of ALL of the A/C stuff and I also had to notch the lower Radiator support to move the Radiator back until it touches the Power Steering. Just barely enough room! I can take some pictures if you want.
Ray
Old Aug 29, 2004 | 10:17 PM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
I'm not incredibly familiar with camaros, but does it have to go between the radiator and the back of the radiator/AC "tray"? It should be easy enough to mount a big intercooler between the bumper supports and the front of the radiator tray, just in front of those diagonal braces. Or am I completely wrong and camaros are totally different in this area?
I'm planning on mounting an NPR intercooler in this area forward of the radiator tray. I should have plenty of room even with it at a diagonal with the top leaning forwards. I even cut and welded the radiator support down 1" and back about 1" to clear a 3" downpipe crossover. My radiator sits completely underneath the metal frame where the AC condensor used to be.
Old Aug 30, 2004 | 12:51 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
We used a core from a semi truck.
The core was 65.5cm ( 25.8 inch ) wide and 6cm ( 2.3 inch ) thick.
The height was 51cm ( 20 inch ) and we cut it down to 42.5cm ( 16.7 inch ) because that was the maximum size that would fit where the A/C condensor was. We had to move the radiator back i bit too. The inlet and outlet are both 3".
Old Aug 30, 2004 | 08:22 PM
Car: 91 Z28
yea thats what i was thinking....it looks to me to have plenty of room but i may be wrong as i havnt removed my bumper yet..
also im cutting some of the bumper (the center section where the license plate would mount) so its one big opening allowing maximum air flow. and to show off the intercooler of course
Terrell351
Jun 13, 2021 01:13 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
E Rod
Aug 28, 2015 05:17 AM
sailtexas186548
Aug 24, 2015 10:11 PM
