Add HP to 2.8
Old Sep 11, 2004 | 02:52 AM
LD1985's Avatar
Car: '91 RS, 1994 Honda Accord LX
Engine: 3.1
Transmission: Automatic
Add HP to 2.8
I was wondering if there is anything i can buy to add even a little horse power to my 2.8? It's Fuel injected....It's not too bad...untill I turn the AC on....after that i might as well just park it....cuz i feel like i have a lawn mower engine under here....
Old Sep 11, 2004 | 08:56 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Head to the V6 forum for those answers....
Pacesetter headers + catback, and TomP's tuneup would be the first things to do.
Then save for the VP turbo kit
Old Sep 11, 2004 | 09:41 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
check out this thread
https://www.thirdgen.org/techbb2/sho...hreadid=259061
Old Sep 13, 2004 | 12:48 AM
LD1985's Avatar
Engine: 3.1
I've done a tune-up..it's not like his is exactly special..it's just extensive...i've done most all of that..and doesnt really add HP. What's tha VP turbo?
Old Sep 17, 2004 | 09:41 PM
LT1guy's Avatar
Car: 1987 Trans Am
The most cost effective "mod" you can do to a 2.8 is remove it and put in a 3.4...there are tons of threads on the V6 board about this. Ked has done it several times, Redraif and I have done it, and there are many others. If you want to stay V6, trust me, this is the best thing you can do for the $. The torque gain is substantial!
Old Sep 20, 2004 | 06:18 PM
LD1985's Avatar
Engine: 3.1
i dont want to stay v6..i was just wondering if there was anything i could do to this enginefor the time being.
Old Sep 21, 2004 | 06:56 PM
LT1guy's Avatar
Car: 1987 Trans Am
If thats the case, save your money for a V8 swap. Theres nothing you can do other than maintenance type stuff, that really helps much.
Old Sep 21, 2004 | 09:49 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
how to fix a power problem in a 2.8
http://www.outlawperformance.com/JYD2.0.htm
Old Sep 30, 2004 | 09:49 PM
Drew's Avatar
Spray it.
Old Sep 30, 2004 | 09:51 PM
Drew's Avatar
Ok, a little more info...
If you're going to pull it out to put in a 3.4 you might as well blow it up first. To be completely honest, unless its on its last legs, it'll handle 75-100hp of nitrous without a problem. Spend about $500 on a universal EFI wet kit, and have fun. Just make sure you have good plugs and the cars running on all 6 cyl and let er buck.
Old Oct 1, 2004 | 12:29 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
I second the spray option, if you're gonna want to swap in the future, it won't hurt it. I also second the 3.4L swap. You'll pick up 40 ft/lbs and 25 hp (more if you do supporting mods). May not sound like much, but I think it's like a 25% power gain. The little 3.4 can really move with the right mods.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
InfernalVortex
Apr 20, 2021 11:31 AM
mrbird
Oct 20, 2015 03:43 AM
gord327
Oct 3, 2015 01:25 PM
usafirebird
Sep 29, 2015 11:58 PM
