Will the NOS TPI kit fit my 52mm Throttle Body?
Old Sep 12, 2004 | 07:50 PM
kingbabone's Avatar
Since it is set up for a stock tpi, will it be the spray bar mounting plate be smaller than my 52mm throttle body.
Old Sep 16, 2004 | 12:42 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
ttt sorry i cant help but i actualy was wondering the same thing, except for a 58mm tb.
anyone, i suspect it wont fit correctly (just think if the spray bar was bigger than stock it might possibly spray outside the openings) but i need some positive reinforcement here.
Old Sep 16, 2004 | 07:12 PM
biggtime's Avatar
I have a new plate for sale, need some meausurements?
Old Sep 16, 2004 | 08:23 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
well if ya wanna measure for us that would be awesome...then maybe we can get someone to measure their 58 and 52 tb's!!!
Old Sep 16, 2004 | 09:08 PM
biggtime's Avatar
The *hole* measures 2.330
Old Sep 17, 2004 | 01:49 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
sweet now well see if anyone wants to measure their 58 and 52mm tb's. once again, thanks a lot man!
Old Sep 17, 2004 | 09:45 AM
biggtime's Avatar
All you need to do is convert MM to inches. The 52 and 58 is the diameter in inches
Old Sep 17, 2004 | 11:07 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
lol
so lets check my math.....the N2O plate opening for one hole is 2.33 inches in diameter correct?
one inch equals 2.54cm
the 58mm tb comes out to ~2.29 inches in diameter.
(58mm = 5.8cm / 2.54 = ~2.29) so both would just fine i think.
is that correct?
Old Sep 17, 2004 | 11:24 AM
biggtime's Avatar
Old Sep 17, 2004 | 10:41 PM
kingbabone's Avatar
talked to Holley... 58mm. Can't wait to install my new NOS!!!!
Old Sep 17, 2004 | 11:46 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
great now lets see some pics!!!
Old Sep 21, 2004 | 10:48 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
more stuff to add to this..........
why is it the TPI plates will only support a 150 shot? are there too little holes on the bar or something?
and what jets do i need to actually make a 150 shot? im getting a used kit that has 125 and 75 jets but i thought jets werent designated "125" etc...
Old Sep 22, 2004 | 12:08 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
The NOS tech told me that the size and number of holes in the plate are same as the plate used in the super power shot and cheater kits (same plate). The cheater kits run up to around 250 hp with the bigger selenoids. He said that the TPI intakes dont have the fuel distribution ability for that size shot. The super power shot sized selenoids in the TPI kit can't flow but around 175 hp max due to the orafice size in the selenoid.
Old Sep 22, 2004 | 08:51 AM
NYIROC's Avatar
Car: 87IROC
Transmission: MAD DOG 700R4 w/3:73 posirear
I just ordered a NOS TPI system. What's the typical HP number to run with a 350TPI.
Also should the timing be retarded when using? What about having the Hypertech Thermomaster chip, will it cause a problem?
Regards,
G
Old Sep 22, 2004 | 11:04 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
so the actual kit is limited due to the soleniods (which could obviously be changed) but the max "shot" is actually limited by the TPI fuel distribution itself.....got it!!
anyone know about what jets i need to run that 150 shot?
Old Oct 1, 2004 | 04:27 AM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
You do not want to run any chip that increases ignition timing. Increased cylinder press from a power adder + too much timing= disaster. I'm not sure if you could get away running that chip and installing something like an MSD timing retard or not though. I would think you could. I'm looking at throwing some N2O on my car, but I want to set the car up to run safely on the giggle gas and lose as little power when not spraying as possible. I was thinking adjustable retard would be a good start.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
italiano67
Dec 11, 2016 09:21 AM
lakeffect2
Aug 23, 2015 08:44 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
