Budget nitrous
Old Nov 1, 2004 | 08:09 PM
cyipher's Avatar
Car: 1984 Pontiac Trans Am
Engine: 305 SBC
Transmission: Automatic
Budget nitrous
Well parts are coming in as we speak, i got all of this for under $200. Dynotune solenoid N20 and Fuel with mounting plate, Nos cheater sprayplate with 125hp jets, lines from solenoids to spray plate, Holley Red electric fuel pump and a old style Nos 10lb. Bottle. Now all i need is a fuel gauge, nitrous gauge, gaskets, main feed line, and some extra time. i hope i will have this installed by next monday. I will post times as soon as i go to the track, but for now you will have to settle for pictures.
Old Nov 2, 2004 | 10:56 AM
a73camaro's Avatar
BIG WARNING!
On that pic, the blue nitrous solenoid, there is a black safty switch that is ment for the fuel side. Do not put nitrous pressure to that switch, it will POP! Put the switch on the fuel side.
Make sure that there are the proper sized jets for fuel and nitrous in the base plate.
Have fun!
Old Nov 2, 2004 | 11:02 AM
a73camaro's Avatar
Here is a post about wiring it up. Also read (via search) about installing the system.
https://www.thirdgen.org/techbb2/sho...hreadid=265233
Old Nov 2, 2004 | 01:12 PM
cyipher's Avatar
Engine: 305 SBC
yeah i know, this isnt my first nitrous install, actually like my 5th, i just tossed that on there so i did lose parts.
Old Nov 3, 2004 | 10:04 AM
a73camaro's Avatar
No problem, I myself have only installed one system. I read a bunch about it and thought out the control circuit.
With the fuel pressure switch on a blue AN adapter, I could see how easy it would be to mix up the location.
Old Nov 3, 2004 | 12:30 PM
Intensity_Z's Avatar
Car: 84Z/ 87 S-10
Engine: 355/350
Transmission: th-350/700-r4
how much did those solenoids run you? got a phone number or website for that company? thanks
Brandon
Old Nov 3, 2004 | 02:42 PM
cyipher's Avatar
Engine: 305 SBC
i got mine for 87.95 sipped with the mounting plate off of ebay from dunotune. they are very high quality and they look great. It doesnt look like he has any for sale on ebay at the monent, but you could always email and ask him for that price or if hes going to have any auctions soon
http://motors.search.ebay.com/_W0QQg...sortpropertyZ1
Old Nov 3, 2004 | 03:04 PM
cyipher's Avatar
Engine: 305 SBC
Well got my fuel pump installed and my summit fuel gauge in and plumbed. Once i find my FP the gauge will be hooked up to the fuel solenoid using a 1/8' male/male fitting.
Old Nov 3, 2004 | 08:16 PM
biggtime's Avatar
Here is how to wire the hobs switch and relay:
The hobbs switch cannot handle load, this is how to wire with a relay.
Potter Brumfield/tyco 40 amp relay #VF4-45F11
bosh relays use the same tab numbers
Relay #86 tab, full throttle switch, hobbs switch (if used), then ground.
Relay #85 tab, 12volt+ from arming swich, (should get its power from a key on power source)
Relay #30 tab, 12 volt 40 amp fused supply (usually direct from bat or solenoid )
Relay #87 tab, to nitrous solenoids
Other wires from solenoids go direct to ground.
Old Nov 4, 2004 | 01:52 PM
cyipher's Avatar
Engine: 305 SBC
Got my nitrous plate installed this morning, needed half inch longer bolts, but the good news is everything clears the hood. I also took pictures of my fuel pump so if anyone want to see. Also you gott love driving around with a Fuel pressure gauge taped to your window, everyone look at you funny.
Old Nov 5, 2004 | 02:06 PM
cyipher's Avatar
Engine: 305 SBC
got the solenoids mounted and plumbed along with the nitrous feed line that i had custom made at 17' and all i got letf to do is mount the bottle, do the wiring and put the sprayplate lines in, but i'm still waiting on the 125hp lvl jets. I think they will be in today.
cheesehomer
Dec 31, 2015 08:48 AM
drumstixer
Sep 29, 2015 03:02 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
anesthes
Sep 18, 2015 12:34 PM
