which turbo's
Old Nov 6, 2004 | 07:26 PM
firebird89355's Avatar
Car: 1989 pontiac firebird formula
Engine: Currently building a 355
which turbo's
ok this is the plan its not gonna be an overnight thing but this is what im planning, im going to build a 355 with 8.5:1 compression,trick flow 195 cc heads 2.02/1.6 valves, a xe284 hydraulic cam(284/296 - .507/.510 - (debating on going with a 750 holley, or tbi unit from a truck with better injectors, aftermarket prom) custom selfmade headers. with dd2000 and with a 750 holley with a t04b v-2 turbo,im assuming that dd2000 only takes into account that someone will only be using a single turbo, using 12 lbs of boost it made 622tq@5500 & 726hp@6500 my question is will that turbo 1. spool up pretty efficiently 2. is that hp&tq a reasonable amount to expect with that combo or is dd2000 very far off from actual numbers according to real world combo's that some of you have assembled in the past. 3. if that turbo isnt going to cut it for my 700-750 hp goal what turbo would be a btter choice. thanx for the help in advance as this will be going into my 89 firebird and i want to be able to run low 10's high 9's in the quarter.
thanx,
THOMAS
P.S. according to the turbo calculator over at www.turbomustangs.com twin t04e v trim would actually be the best turbo for my combo but of course dd2000 doesnt have that listed so i couldnt see the power i might make with those turbo's.
Old Nov 7, 2004 | 04:09 PM
come on guys
please reply to this i really need some help.
THOMAS
Old Nov 7, 2004 | 06:22 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
For a 350ci V8, TWO of the V2 trim T04Bs will be MUCH more efficient. For a single, go with at least a T76!
Old Nov 7, 2004 | 07:28 PM
thank you
ok so now that i have that question out of the way,what about fuel? should i go with a properly modified holley 750 dp or should i rip a harness and TBI out of a truck with the appropriate sensors and use it. and also does that combo sound reasonable for the power that im expecting?
THOMAS
Old Nov 7, 2004 | 08:27 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
That is too much cam for a 350 with 8.5:1 It wont want to idle. I would look into a blower friendly cam on a 112 LSA.
Old Nov 7, 2004 | 08:47 PM
o.k. i said i was new to this
would you care to elaborate a little more as far as lift and duration goes that would help out alot.
THOMAS
Old Nov 7, 2004 | 11:31 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yeah, your cam is HUGE.
lift aint bad, but try a xe274 or 276 i think, the one with 224/230 at .050" valve lift. that be pretty good.
Old Nov 8, 2004 | 12:24 AM
Re: o.k. i said i was new to this
THOMAS
Something in the neighborhood of 228/238 @ .050 with a decent amount of lift on a 112 LSA.
Old Nov 8, 2004 | 09:54 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
You'll probably want even or less exhaust duration and maybe a larger overlap on the cam. It's been discussed a few times.
Old Nov 8, 2004 | 08:55 PM
hows this sound
its a marine cam that i found on compcams website.
Camshaft Specification Table
Part Number 12-240-4
Engine 1955-1998 Chevrolet
262ci-400ci
8cyl.
Grind Number CS XM 270H-12
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.48 0.489
Duration At 0.006 Tappet Lift 270 286
Valve Timing At 0.006
Open Close
Intake 25 65
Exhaust 77 29
These Specs Are For The Cam Installed At 110 Intake CL
Intake Exhaust
Duration At 0.05 226 236
Lobe Lift 0.32 0.326
Lobe Separation 112
lemme know what you all think.
Old Nov 9, 2004 | 09:15 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
I think it has too much exhaust duration. CompCams has a few mild off the shelf turbo cams. For reference, I've got a CompCams custom cam - Extreme hydraulic roller lobes, @.050, 236 intake, 230 exh, and 113 LS. Don't forget exhaust backpressure is about 1 to 2x boost pressure.
Old Nov 14, 2004 | 05:44 PM
what about induction what would you all use and why, pro's and con's of each if you dont mind , i dont mind having to tune as long as it will be dependable and meets my expectations as far as reliabilty and power. also im still looking at cam profiles, just havent decided on 1 yet.
THOMAS
Old Nov 15, 2004 | 03:52 AM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
go back to dd2000 and put in the specs for a stock lt1 cam. do it with 1.5's and 1.6's. lets see what kind of diff. it makes. i think you will be suprised.
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
