Head bolts torque patterns.
Old Jan 10, 2005 | 01:22 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
anybody know how to torque the head bolts on aluminum 350 pre -87 heads? I know the torque specs of 65 lbs, but not the pattern to torque them.. Do you have a link, i really want to get this thing running. -J
Old Jan 10, 2005 | 02:17 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
I don't have a torque pattern handy, but its pretty straight-forward. Start at the center bolts at tighten in an outward fashion. So like, the first center bolt in the head, then one to the left of center, one to the right of center, etc etc. I'm sure someone will chime in with the 'official' patterns that are printed, but they all are pretty much saying the same thing, just keep your count, and don't forget any.
here is something more important though:
tighten in steps, so if 65ft-lbs is the final torque, step in like hand tight, then 30ft-lbs, 45, then 65. try and step in equal-ish amount, but above all when closing in on the final torque, keep a nice even stroke, and get a smooth click or needle sweep on your wrench. so for instance, don't try torqueing to 62 ft lbs, then try to get to 65, since you will be fighting static friction breakaway torque and may tighten more than spec.
also, make sure you use some kind of thread sealer. myself, I use plain old ultra-black RTV, and never had a failure, but the 'correct' stuff is a dedicated thread sealant.
Old Jan 10, 2005 | 03:04 PM
Car: 1987 GTA
yeah, that's what i thought, but I heard something about a triangle pattern, starting in the center. anybody know? thansk -Justin
Old Jan 10, 2005 | 04:35 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
here you go
Old Jan 10, 2005 | 09:10 PM
Car: 1987 GTA
thank you very much! and that's for the pre-87 or pre centerbolt heads right? i appreciate it!
Old Jan 10, 2005 | 09:12 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
doesn't matter their all the same.
Old Jan 10, 2005 | 09:15 PM
Car: 1987 GTA
thanks so much! i've been looking all over for this! thanks-Justin
Old Jan 11, 2005 | 06:35 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
make sure you use thread sealer or loctite red on the bolt threads.
Unless you want water crawling up the threads.
-- Joe
Old Jan 11, 2005 | 06:51 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
You could by a book. They have all kinds of usful information. Like tq. sequences and firing orders, trouble shooting, really great stuff!
Old Jan 11, 2005 | 08:33 AM
Car: 1987 GTA
i bought the how to rebuild a small block chevy,,,,didn't see it in there, but anyway, see how great the net is. But thanks for the recomendation...that is very insightful.
Old Jan 12, 2005 | 06:08 PM
Car: 1987 GTA
Do you use RTV on the head gasket anywhere?
Old Jan 12, 2005 | 07:52 PM
BlownBird's Avatar
No...
You will not need rtv anywhere on the head gaskets.
Old Jan 12, 2005 | 10:04 PM
Car: 1987 GTA
Hey Don,
How ya been? I built my own motor, did the entire assembly and blueprinting, etc. It's a blower shortblock...anyway, thanks for the reply...how is your car,..how fast? also, do I need RTV on the front main seal where is touched the timing cover? and RTV on the timing cover gasket? thanks.....good talking to you.; -J
Old Jan 13, 2005 | 06:44 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hey Don,
There is only two places on a SBC (roller motor) that you need RTV:
1) Both ends of the intake manifold
2) Around the water ports on the intake manifold gasket (both sides).
On earlier SBC's, the oil pan gasket could use some on the cornors.
Everywhere else, thats what the GASKET is for. A clean gasket surface will never require RTV.
-- Joe
Old Jan 13, 2005 | 08:52 AM
Car: 1987 GTA
thanks for the info,....I was gonna put some on the fuel block off plate too,...but now i won't. I remember the intake water ports though, and the ends of the intake,....everyone uses RTV there, and doesn' use the cork correct? thanks. -J
Old Jan 13, 2005 | 04:48 PM
BlownBird's Avatar
Justin,
Anesthes, is right on the money!
I've been buisy with family and work, so I never fully tested the combo I was building. To date it has gone 10.00 @ 144 with a bad 60'. I have since built a new motor with a bigger blower, it will be ready for spring. I am looking to be a lot faster with this combo.
Hope all goes well for you, keep in touch!
DonB
Old Jan 15, 2005 | 09:03 PM
Car: 1987 GTA
Good to hear don,,, not sure how fast i'll go,...hopefully in the 11's///...keep me posted via email on the new combo,...i'm glad to almost have mine done! where does the oil pan gasket get the rtv? all 4 corners???/ by the timing cover corners? thanks
Old Jan 16, 2005 | 06:07 PM
Car: 1987 GTA
another question:
my freind tells me to pre-lubge the oil pump w/ white lithium grease so it starts wet, and also says to put white lithium on all the oil pan gaskets to help it stick while i set it in place,...etc..what do you think of this?....or do i just need a dab of rtv on the 4 corners of the pan gasket and the 2 ends of the timing cover.? thank s
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 25, 2015 12:54 AM
86White_T/A305
Aug 17, 2015 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
