Got one of the Turbo Headers built - Pics!!
Old Mar 31, 2005 | 01:08 AM
calereeves's Avatar
Car: 78 T/A
Engine: 454
Transmission: TH400
So I got busy over spring break and in about 6-7 hours I got my driver's side header totally tacked up and ready to be tig welded. I need to tweak the collector some and add a bend to the end to be able to make the turbo
face the other direction, but otherwise its good to go. I can't wait to get back this summer to do the passenger side! I left the first pic big so you can see how close it comes to the upper A-Arm... it was a tight fit to say
the least! The first tube took me about 2 hours to get right, then the rest all came very easily afterwards. I've never done any fabrication on this level, so I'm VERY proud of how it came out. And yes, I know I blew a hole
in the number 1 tube... got the 220V ESAB welder a little hot I guess!
Old Mar 31, 2005 | 01:19 AM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Re: Got one of the Turbo Headers built - Pics!!
Originally posted by calereeves
Planning on running arad hose? Looks pretty tight.
Old Mar 31, 2005 | 01:39 AM
calereeves's Avatar
Car: 78 T/A
Engine: 454
Transmission: TH400
Nah...I figured I'd just block it off
Actually, I'm probably going to go with a Griffin Rad with a custom outlet. Plus the turbo is going to face the other direction(where the downpipe will be pointed to the engine bay) and will be dropped about 2 inches. I'll probably use hard tubing for the rad hose with silicone connections.
Cale
Old Mar 31, 2005 | 11:53 AM
High Toned SOB's Avatar
Car: 85 T/A
Engine: BBC
Transmission: glide w/brake
what kind of pipe is that? thickness, etc.?
Thanks,
Mike
Old Mar 31, 2005 | 12:04 PM
calereeves's Avatar
Car: 78 T/A
Engine: 454
Transmission: TH400
16 or 18 ga 304SS
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
