super ram install tips.
Old Apr 11, 2005 | 08:55 AM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
what are the torque specs for the plenum lid bolts, the plenum runner bolts and the runner manifold bolts?
-also, is there a way to download the SR install directions anywhere? well...i guess all i really need is the bolt specs.
-also, I tried to take off my plenum lid, but after i took the bolts out, it was stuck. What do you think the best way to do this is...thanks?
Old Apr 12, 2005 | 12:45 PM
Dzhezkov's Avatar
Car: 88 GTA
Engine: 406ci
Transmission: Tremec 3550
There are small bolts(4 each side I think) that go in from the outside of the plenum, up through the runners and into the plenum, then there are the bigger allen wrench bolts on the inside of the plenum, remove those, and the vaccum tubes, and the plenum should lift off. Careful of the temp sensor that's on the bottom, unclip the wire before lifting too far. It's been a while since I did my super ram, but it takes a lot of patience.
Remove the valve covers, and remove some rockers, you'll know which ones to remove when you try and get to the bottom bolts that hold the runners to the base. You'll need a long allen wrench I forgot the size. Though most are, a few of the bolts are not all the same size, make note of which bolt you pulled from where.
Good luck, and stuff rags into the runners when working, dropping a bolt down there would suck.
Old Apr 12, 2005 | 03:08 PM
Car: 1987 GTA
thanks,...but my problem is detaching the lid from the plenum, not hte upper plenum from the manifold. I took out alll 17 bolts...but it's still stuck, any ideas? thanks. -
Old Apr 12, 2005 | 05:16 PM
lead foot 85's Avatar
Car: 85 corvette
Engine: 383 superchaged
Transmission: 4x3
Just use a screw driver or something simular to pry the lid off......
Old Apr 12, 2005 | 11:56 PM
Car: 1987 GTA
ok, i just don't want to screw up the surface
Old Apr 13, 2005 | 08:36 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Smack the top of the lid with a hard nylon mallet. It should break it loose from the gasket. You could also get a brass punch, and tap the lid on the side, again to break it loose. No need to pry, since there should be enough clearance to move it sideways. Last resort you can always remove the throttlebody, and push up w/ your hand from the inside.
Old Apr 13, 2005 | 08:48 AM
Car: 1987 GTA
good idea,...i removed the TB already, no help...but i'll try the punch or mallet method,...just afraid to crack the casting.
Old Apr 14, 2005 | 12:18 PM
Dzhezkov's Avatar
Car: 88 GTA
Engine: 406ci
Oh heh, never had my lid stuck on real bad. Mine always popped off with a big flat head screwdriver. You may be able to use some sort of solvent to break up the gasket material and sealer around the edges if all else fails.
Old Apr 14, 2005 | 01:25 PM
Car: 1987 GTA
got it with a little prying.
Azrael91966669
25
Jun 20, 2017 04:04 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
fonzie85
Aug 13, 2015 11:50 AM
bryan623
Aug 10, 2015 11:33 AM
