Turbo Project done ...for now
Old Apr 16, 2005 | 07:12 PM
TwnTrboZ28's Avatar
Old Apr 16, 2005 | 10:20 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
whoa! that thing is seriously budget! i love it! how's it run? and what's with the hood?
Old Apr 16, 2005 | 10:40 PM
TwnTrboZ28's Avatar
I still have some carb tuning to do. I plan to get the EV carb hat which should clear some things up.
I saw an original hood w/o louvers at the junkyard for like $30. My orig. hood had louvers, and i did not want to cut up the orig. hood, and I did not want to buy a cowl for $$$. So, I just modified the jy hood so it has an extra wide 4' cowl. <-- kinda temporary to save $.
Yes it is budget. Last year I had a decent short block (forged pistons, custom comp cam,....etc) but it ran lean and I F'ed it up (holes in pistons). So, I said screw it, went and pulled a short block from the junkyard from a chev. truck for $100.00 and threw it in.
Old Apr 17, 2005 | 07:26 PM
Balael6's Avatar
Car: 1988 Formula
Engine: Twin Turbo .60/.63 305
Transmission: T-5 5 speed
How hot does it get under that hood? even with all the wrap on the lines? i'm just asking since I have a TT 88 Formula, and am curious as to how hot everyone elses under hood turbo systems are.
pj
Old Apr 17, 2005 | 09:22 PM
TwnTrboZ28's Avatar
With proper timing/jetting it stays below 190 unless I get on it a lot.
Old Apr 17, 2005 | 09:25 PM
Balael6's Avatar
Car: 1988 Formula
No, i mean underhood temps, heh.
pj
Old Apr 17, 2005 | 09:54 PM
daverr's Avatar
looking good.How much boost u running???
did u build those headers yourself??
Old Apr 18, 2005 | 12:46 PM
TwnTrboZ28's Avatar
I am running 8-9 lbs of boost. The headers are the s10 v-8 conversion headers flipped upside down, the only clearence issues are the brake lines but you can just bend them a little and they clear fine.
Under hood temps = Really HOT. I need to put some type of heat shield on the turbine housing because the outside of the fender gets so hot you can burn your hand.
Old Apr 18, 2005 | 12:49 PM
Balael6's Avatar
Car: 1988 Formula
Ok, cool, me too, I'm running about 7psi through two t3's, and it gets mighty hot underneath the hood, even with the headers wrapped, next step is to bag the turbos, and wrap the downpipes.
pj
Old Apr 21, 2005 | 03:18 PM
Formula 89 Bird's Avatar
Car: 89 Formy
Engine: 305--->TPI 350
Transmission: auto :(
do you think the s10 headers would have enough clearence for twin t3's? Also are those s10 headers for 4wd or 2wd s10's? Thanks
Old Apr 21, 2005 | 04:05 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
pj
can you post pics of your setup? I'm doing a TT setup also.
Old Apr 22, 2005 | 02:43 AM
TwnTrboZ28's Avatar
[Napolian voice] Heck yes they would!! [/Napolian voice]
I think 2 wd, .... is there a difference?
Got it running pretty good today, ran it through 1&2nd gear. It pulls like a raped ape!
Old Apr 26, 2005 | 10:28 AM
Balael6's Avatar
Car: 1988 Formula
here's the only pics I had, I was going to take some better higher resolution ones, but it's been snowing, and raining here for the past week.
this is a junkyard to the extreme project, and it worked out quite nicely, I haven't gotten it to the track, or dyno yet, but it is definately a very large improvement. 3rd gear is just and endless pull now, along with being able to spin em from a roll now, which I could never do before.
The headers are an extremely simple design, which you can end up placing the turbos pretty much wherever you want if someone were to repeat the design.
pj
Old Apr 28, 2005 | 06:45 PM
daverr's Avatar
Old Apr 29, 2005 | 11:30 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
Balael6, what size of pipe is going from the header to the turbo
Old Apr 30, 2005 | 01:06 AM
Balael6's Avatar
Car: 1988 Formula
It's 3 inch, from the collector of the header, to a 3 to 2-1/2 reducer, to flange, then turbo.
pj
Old Apr 30, 2005 | 12:56 PM
Balael6's Avatar
Car: 1988 Formula
Twntrboz28, did you take it to a track/dyno yet? What kind of turbo is that? and what is it off of? How soon do you hit 8-9 lbs of boost?
pj
Old May 1, 2005 | 12:40 AM
TwnTrboZ28's Avatar
pj
I dont have any times yet, still kinda tuning it. The turbo is a master power T-70. They make them in brazil or something, and they are very popular on turbomustangs.com . I have a 3000 stall and I hit 8-9 lbs by 3400-3500 rpm. I also just added a 1st gen dsm blowoff valve, I'll add some pics soon.
Old May 1, 2005 | 12:53 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
what turbine a/r you using and whats the specs of the cam
Old May 2, 2005 | 11:39 PM
TwnTrboZ28's Avatar
The turbine a/r is .96 and the cam is JuNkYaRd SuPeR StOcK Yo! (I have no clue what cam is in it) I did however put a set of 1.6 roller rockers in which probably helps slightly.
BTW, yesterday I put in a mallory hyfire 6 digital ignition. It seems that with the new ignition it runs richer at idle, is this normal?
It has been running really good, it will burn the tires through 1st and 2nd (havent tried 3rd yet) by just rolling into it. I think it is time to take it to the dyno to see just how much boost I can put through it.
Old May 3, 2005 | 11:38 AM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
how hard is it make an turbo setup and how much money?
Ps.. MY FELLOW WASHINGTON
Old May 3, 2005 | 01:01 PM
TwnTrboZ28's Avatar
If making them yourself turbo setups can be very diffucult without the right tools and experience. I managed to get by with a flux core welder, angle grinder, drill, dremmel tool, saws-all, bench vise, a set of end wrenches, ratchet set, some vice grips, screwdrivers, and a big hammer.
As far as price, you can spend anywhere from $500 to 10,000+.
Depends on the quality of componets, how much stuff/work you can get for free/cheap, and how much time you have.
You can prettymuch get any question answered with a search either here or at turbomustangs.com
Old May 3, 2005 | 05:09 PM
TwnTrboZ28's Avatar
bov pics:
Old May 4, 2005 | 03:12 PM
i Know a place here in Washington that does ceramic coating.. to help w/ the temps if you are intersted. They are kinda on the expenise side. but its an idea
http://www.performancecoatings.com/
They had a huge hotrod/Bike show at the tacoma dome and they had alot of cars they did and they had and nice booth w/ examles.
Hotrodboba400
Dec 10, 2019 07:07 PM
ZZ3Astro
Aug 13, 2019 12:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
