Need a check valve.
Old Jun 2, 2005 | 05:13 AM
IROC-Turbo's Avatar
Need a check valve.
Need a one way check valve that fits in the small vacuum lines.Any ideas??
Old Jun 2, 2005 | 03:49 PM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
Try your local pet store, no really.
Old Jun 3, 2005 | 04:45 AM
IROC-Turbo's Avatar
You're thinking of the hampster watter bottle head with the steel ball in the end??Never thought of that.It being steel it should handle the boost too!!Thanks
Old Jun 3, 2005 | 10:43 AM
cyipher's Avatar
Car: 1984 Pontiac Trans Am
Engine: 305 SBC
Transmission: Automatic
no i think he was trying to imply the fish tank water check valves for air pumps.
Old Jun 3, 2005 | 02:37 PM
Car: I
Engine: Taunt
^^Yup^^
Old Jun 4, 2005 | 08:55 AM
IROC-Turbo's Avatar
Never thought of that either.What are those made of??At first i used a check valve from a 3rd gen f-body's windshield washer sys.It worked great but i tryed to remove it to see if it was still operational after i put it under boost and it popped apart at its seam.After searching the junkyards and my parts cars i couldnt find another that was operational.No pet shop close but i'll see what i can find next time im outa town.Thanks
Old Jun 4, 2005 | 07:49 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Can I ask what you need this for ? I have nooo idea . My turbo was shipped today ....and wouldn't mind hereing of any of these litttle thnigs
Old Jun 5, 2005 | 10:06 PM
IROC-Turbo's Avatar
I have a drawthru turbo sys and i need the check valve to regulate the primary metering rods on a boost referenced quadrajet carb.The factory used a sys called a Power Enrichment Vacuum Regulator.Without the special throttle plate and gasket and pevr the primary rods would be thinking its under a high vacuum situation when the turbo is boosting and would close the primary jets.The one way check valve will let the carb see reg vacuum measures without boost but when boost was applied the check valve would close off vacuum and pressure to the power piston that controls the primary rods and make it think its in a WOT situation and will open the primarys fully.
skeltor
Feb 2, 2016 10:37 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Nick McCardle
Sep 10, 2015 08:36 PM
