Bottle to hot
Old Jul 22, 2005 | 09:27 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Bottle to hot
I have a 75 Vette The NOS bottle is
in the rear compartment How hot is to hot
and what will happen
Old Jul 22, 2005 | 10:04 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
you should have a bottle gauge,
they have a zone on there where the bottle should be, to hot it goes to the danger zone, not sure what psi that is
but you can risk explosion (more so by using like a propane torch)
Old Jul 23, 2005 | 01:15 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Too hot and your burst disc should rupture, wasting your whole bottle of nitrous, around 900-1100 psi depending on your tuning is ideal. Its best to take the bottle out of the car when its going to be parked on a hot day.
Old Jul 23, 2005 | 08:11 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
I tune my cars nos with bottel pressure around 950-1000psi. If the bottel temp gets around 1200-1300psi it wont blow the disc but your nitrous soilnoid also will not open. That can cost you a race. Also if you tune the car with 900psi bottel and you turn around and bump the bottel pressure up to 1100 psi you will run lean wich can cost as little as a set of plugs or as much as a couple of pistons.
Old Jul 24, 2005 | 01:30 AM
TragicPark's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L V8 TPI
My dad has a 77 vette with a NOS bottle in the middle of the rear compartment and even in 102 degree weather the bottle didn't rupture the disc in the blowoff valve. No he doesn't stack discs or anything but he does park it in the garage except for when he's at work. So far he's had no trouble with it whatsoever.
~Roger
Old Jul 24, 2005 | 01:25 PM
89406Iroc's Avatar
The NOS safety disks are rated to 3300 lbs. / Likw ross said a NOS brand solenoid will not open if the pressure is above 1200#. Bottle temp around 90 degrees is about where you should be at.
Old Jul 24, 2005 | 01:31 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
How quickly does a 10lb bottle get to the same temp as the cars interior? Ive been conserned with buying a nitrous system, and keeping it cool, would like to keep it around 900-1000, but thats what, 85-95*, it does get hot in these cars(like anyother) but how can you keep a bottle cool?
Old Jul 24, 2005 | 01:37 PM
89406Iroc's Avatar
I don't know how quickly it would rise to interior temp. / a Bottle blanket would help alot to keep the Sun from shining right on the bottle if you mount it in an exposed hatch. I have never had mine exposed to direct sunlight in the back so I really don't know.
Old Jul 24, 2005 | 10:46 PM
Car: 87 Firebird
Engine: 5.3 76mm
I was planning on mounting it in the spare area, lost the spair for wait long ago
Old Jul 24, 2005 | 10:58 PM
89406Iroc's Avatar
my bottle is in the spare. It works good and you can suprise some people if needed.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
