How do you avoid this
Old Nov 18, 2005 | 06:02 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Ok I am thinking about running a 125 to 150 shot of the juice. But I dont want this to happen.
http://videos.streetfire.net/Player....1BD5FBDD33&p=0
What steps do I have to take to avoid this.
Old Nov 18, 2005 | 06:07 PM
Scheister's Avatar
Car: 85 IROC
link doesnt work
Old Nov 18, 2005 | 06:12 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
what happend in the vid?
If your wanting your engine to live, get colder plugs, retard the timeing about 4-6*, and make sure u have a good enough fuel system to keep up. I would recomend going to a dyno to fine tune your jeting and bottle pressures.
What motor do you have? Any plans on rebuilding?
Old Nov 18, 2005 | 06:59 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Fixed link.
I have a 406 with forged pistons stock rods and crank. I have a msd 6al, blaster coil, and wires. Fuel system consists of -8 feed and a -6 return. 255 lph fuel pump. Also intake is a tpis big mouth.
Old Nov 18, 2005 | 07:44 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
#1 Don't use the typical "wet kit" in an intake meant for dry flow only.
#2 Use a race plug better suited to nitrous rather than a street type of spark plug.
Old Nov 19, 2005 | 12:50 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
also dont hit it at low rpms
Old Nov 19, 2005 | 02:37 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Well here is my plan of attack. TPI nos kit, zex bottle warmer with thermostat, msd digital window switch, and a full throttle switch.
Old Nov 20, 2005 | 02:09 AM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
dont forget the low fuel pressure saftey switch
Old Nov 20, 2005 | 10:55 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
oh yeah forgot about that one. I think with all that stuff I will have a safe nitrous system.
Old Nov 21, 2005 | 12:51 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
yep thats what i have on both my cars, accept my camaro doesn't have a fpss since it has such low fuel fressure, but i would never run nitrous with out BOTH WOT switch and MSD window switch and i wouldnt recommend spraying anything lower than 3000 or 3500 to be even safer, i spray 3k on the camaro and 3500 on my grand prix, you also need remember about timing and spark plugs, and fuel and the internals if u are stepping up past 125 shot IMO just use it correctly and dont get spray happy and throw 200 shot jets in on a cast bottom end
Old Nov 21, 2005 | 02:51 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
What would you recomend for plugs. Right now I have stock ac delcos in the car. What ever came on a thirdgen with a 350. I also have forged pistons. I was thinking of spraying at 3000 rpms. I only rev. the motor to 5200 rpms.
Old Nov 21, 2005 | 06:42 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Autolite AR12
Old Nov 21, 2005 | 07:35 PM
Mike-91 Formula 350's Avatar
Also don't try it on a Cobra like that guy did!
Old Nov 21, 2005 | 11:05 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
From what I have seen cobras perform vary well on the spray.
Old Nov 21, 2005 | 11:29 PM
Car: 91 z28
NGK's or Autolites seem to work well for nitrous
dcd2236
Exterior Parts for Sale
Aug 19, 2018 02:27 PM
2012sergen11
Oct 13, 2015 07:38 PM
project89
Sep 22, 2015 09:35 PM
E_S
Aug 29, 2015 04:09 AM
blue86iroc
Aug 13, 2003 03:09 AM
