Single Turbo LS1 Swap Drag Project.
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
So we have been sitting on this car for about 6 months now as a rolling shell at our shop. We have an Iron block LS1 laying around, an air to water intercooler, and just about every part necessary to build another drag car. So in true hot rodder fashion we started gutting.
Haven't decided on the specs for the turbo yet but we have come to decide it will be a huge single. I will try to keep updated on pictures as preogress is made.
If anyone is intererested in interior parts let me know. Had the red and black in it. Almost all is for sale. Including anything wiring or climate related.
Axle/Gears: BW 3.23
Sorry have't been online in awile. Yes it is a 6L truck block we will be using in order to get some cubes without having to mess with sleeves. Here is a couple pics of us playing around with parts around the shop getting ready to start mocking a few things up.
it's bigger then that... scaling that picture and knowing that 20 is 65mm across it looks to be about a 72mm inducer and about a 5.35" inlet bell...
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I guess you are right about the size. I get all confused with turbos because everyone tends to measure them with $20 bills, beer cans, cell phones, etc. I use a tape measure for sizing up stuff so measuring something with anything other than that tends to throw me.
A 72mm would work nice.
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
just keep adding boost till something pops... then rebuild and backoff a lb or two...
p.s. guessing 10psi at 10:1 compression(non-intercool)/// 15 with
Acually if this is a straight drag car. just keep throughing money at it till it is in the 7's...
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by Guido
I have a similar project in the works.
pfft, that guy obviously doesnt know what hes doing..... he has the intake manifold on BACKWARDS..
looks good, any completely mocked up pics so we can see how it all fits together?
Car: 2000 Trans Am
Nah. I got the drivers side header done but I still need to build a crossover tube. Didnt get around to it late in the year and we put the car back in the trailer for the winter. too cold to work out in that ****. LOL
Ill take it up in the spring and finish it up then.
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Single Turbo LS1 Swap Drag Project.
it looks like you are racing Bill's MR2 at Gateway ?
I have a friend here that's doing a T-76 single in his 98 T/A.
Street Lethal
Apr 30, 2019 12:14 PM
