Pro Charger #'s
Old Jan 15, 2006 | 06:52 PM
SeeYaSucker's Avatar
Pro Charger #'s
Post your HP #'s and or your Times with the Procharger systems. P600B, P1SC, or D1SC. Just Curious as the power they are making.
Old Jan 15, 2006 | 07:19 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
D1SC
3-inch Intercooler
Water Injection
14-psig Boost
36 Degrees Total Timing
305 TPI
700R4
4200 Stall Vigilante
3.73 Limited-Slip
3900 Pounds (with me)
Those are just the basics. Never dynoed.
12.004 @ 117.62 mph
Basically coasting in "OD" for the final two seconds due to reaching the redline (6200 rpm) in "D".
I have since gone to a different setup.
Old Jan 15, 2006 | 07:26 PM
Those are good #'s for a 305
Old Jan 15, 2006 | 07:48 PM
Willie's Avatar
Thanks. I forgot to mention that it's emissions legal, was my daily driver at that time and had full accessories (A/C).
Willie
Old Jan 15, 2006 | 11:56 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
a friend of mine is running a F-2 on a 408. no intercooler 18psi , ran 9.08 @ 151 on 275-60-15 on drag radials weigh's 3300lb's . he is working on installing a intercooler now so he can turn it up!
Old Jan 17, 2006 | 07:37 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
What do you think a 88 Vette will run? With Rear 3.54, 700R Trans shift kit, Motor bottom end stock, mild ported stock runners,pleuim,base and AIr foil. 180 therm, custum chip if need be. just a guess will work for me. car has 98k on it everything is mint. With a Procharger 6lb boost
Old Jan 17, 2006 | 11:45 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
406, D1-SC. 15lbs 780hp.
Old Jan 18, 2006 | 04:06 PM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
Stock motor with cam + bolt ons(D-1SC) @ 8lbs.
13.5@105mph 5500ft. elevation
343rwhp/375rwtq SAE
Forged motor with heads/cam/etc. 355ci (D-1SC) @ 15lbs
No times yet
505rwhp/640rwtq --> ran out of fuel at 4800rpms so it should have more in it.
This was with a 3 core intercooler.
Old Jan 25, 2006 | 02:24 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Totally stock LS1 engine with stock manifolds and exhaust running 9 psi boost at 6000 rpm with a P1SC procharger I made 490 rwhp and 442 ftlbs.
Old Jan 25, 2006 | 03:44 PM
F1RBlownbird's Avatar
406 SBC
F1R @ 18lbs
Spearco A/W IC
Never made good numbers on the dyno due to some complications but if you do the math......
3580 lbs - 9.20 @ 151 = 925 RWHP
Funny part is I'm not even working the blower that hard......yet
Old Jan 26, 2006 | 10:28 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Originally posted by F1RBlownbird
406 SBC
F1R @ 18lbs
Spearco A/W IC
Just curious...Are you using a stock block? I plan to build a forced induction 406. Can't decide on procharger or turbos. What times would you estimate with an air to air IC?
Old Jan 27, 2006 | 10:35 AM
I'm using a Dart Litte M block. I dont recommend using a stock block on a boosted application if you plan on running over 12 #'s. Been there done that and cracked a cylinder @ 14#.
A/A IC are alomst as efficient as A/W if you spend the money and get a good quality unit. Of course placement is a key factor. The difference is you will have to run less timing due to the higher inlet temps.
Turbos are the hot ticket right now but you can make plenty of power with a good S/C like a YSi or F1.
Grant2k
Apr 4, 2016 08:21 AM
tmellott89
Oct 14, 2015 02:06 PM
djmarch
Oct 2, 2015 10:41 PM
jbates346
Sep 22, 2015 05:22 AM
Formula_88AE
Sep 3, 2015 01:47 PM
