tta turbo in a l98
Car: 88 GTA
Engine: L98 350 TPI
Transmission: 700 R4
tta turbo in a l98
how much boost would u be able to produce from a turbo from a 89 TTa and info about doing a swap would be appreciated
Thank you Tommy
Thank you Tommy
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
Not too much useful boost. The turbo itself can support well over 20psi when properly matched to an engine. Just one of those on an L98 will peak early, then be severe a restriction at mid and upper rpm power. It will heat the charge air excessively and overspeed, causing the turbo to fail prematurely. You need to buy and read the books listed int he stickies above before you touch another turbocharger. Asking what PSI a turbo can make proves that you are not ready for a turbo project.
Car: 88 GTA
Engine: L98 350 TPI
thanks for the info i havent messed with turbos to much and i wasnt quite sure how to word it. i was probily getting the turbo for close to nothing so i was wondering if it would benifit me thanks for the reply
tommy
tommy
You might be better off selling it. Or find another one to do a twin system. There is a guy over on Turbomustangs that has two of those on his TA and out 570Hp to the rear wheels!
You got to do some reading before you get the far though. Buy both 'Turbochargers' by Hugh MacInnes and 'Maximum Boost' by Corky Bell.
Car: 88 GTA
Engine: L98 350 TPI
ill look into getting that book the turbo i was gunna get most likly needs a rebuild i work for a speed shop in ny and we deal with turbonetics so im going to do some more research and get some prices. where did u get that book from
Get both of the books I mentiones.
My set-up is all home built. I used two junkyard T3 turbochargers which I found to be severely restricting my upper power band. With 6psi of boost it put down 328rwhp at 4200 rpm and 467rwtq at 3400rpm. This was on a completely stock L98 with 95,000 miles.
I have since upgraded to T3/T4 turbos and have yet to dyno it. I expect a big improvement in HP, but the TQ should be about the same, unless I increase the boost.
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Do a search for gncalculator.xls on this board. It will give you a link. It is a very useful tool for playing around with what you will need for turbos.
I am curious how much of a restriction the JY turbos were vs. how much a restriction the TPI unit is. It is interesting because a stock TPI makes peak HP around 4400 - 4800 rpm. I would think that the turbo powerband should follow the N/A powerband for the most part.
Doing a guestimate calc. comes up with 400fwhp at 4200 rpm for your setup when boosted at 7psi-intake, 8psi-comp._outlet on a cool day. That equates to about 20lb/min at 1.65 PR. About at the 60% efficiency point of a 45 trim T3. What is your guess at the HP with the twin hybrids?
Did you have 45 trim (40mm comp. wheel inducer) or the 40 trim (34mm comp. wheel inducer) Volvo T3s?? They are both marked .42 A/R on the compressor but have different inducer diameter / comp. wheels.
Car: 88 GTA
Engine: L98 350 TPI
the main reason i posted this was i can get my hands on a turbo from a tta probily for cheep and i was wondering if it would be worth doing that for now cuz im goin to be building a motor and doing the t56 swap but money is tight living alone in nc for now goin to NTI and im getting bored so i thought some cheep speed but in the future im goin to be doing a bigger turbo set up but i appreciate all the info i can get here always up for learning
thank you
tommy
thank you
tommy
Car: 88 GTA
Engine: L98 350 TPI
thank you
tommy
thank you
tommy
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
Not worth anything unless you use two to power a v8 project......
Nothing different from a GN turbo, better money spent elsewhere...
Linson
10-01-2015 09:50 PM
