Nitrous?????? How Much
Old Feb 4, 2006 | 10:17 AM
CamaroSS_Black's Avatar
Car: 1986 Z28
Engine: L98 Block Vortec Heads Comp Xtreme
Transmission: Built 700R4
Axle/Gears: 10 bolt with Auburn 3.73 posi unit
i have a l98 out of a 89 350 formula with vortec heads a xtreme energy cam perfomer intake and 650 carb i wanna know if anybody has any opinions of about how much nitrous i can run safely with out going boom...and if anybody knows any good kits for a carborated engine thank you
Old Feb 4, 2006 | 05:55 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
For a stock bottom end you should be safe with between 100 and 150. Make sure you dont lean out thou. All the forged internals in the world wont save you from that.
Old Feb 5, 2006 | 10:31 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Yeah you can put a 150 shot on it and be ok as long as your fuel and ignition systems are in good working order. A good entry level kit is the NX Hitman kit PN 40041 I belive. Its a very simple and effective kit.
Old Feb 5, 2006 | 11:34 AM
Car: 1986 Z28
i have a carb can i still run the same amount?
Old Feb 5, 2006 | 09:04 PM
Shagwell's Avatar
Car: projects.......
you can run just as much N2O w/ carb as you can EFI. No matter which though, your fuel/ignition system have to be up for the task...
Old Feb 5, 2006 | 11:20 PM
Car: 1986 Z28
my buddy said something about cooler plugs? what would i need to make my ignition system up for the task
Old Feb 6, 2006 | 08:23 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Basicly these are the rules to be completley safe. Make sure fuel and ignition systems are in perfect working order. Retard timing 2 degrees for every 50 HP of juice and 2 step colder plugs.
Old Feb 6, 2006 | 02:03 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Old Feb 6, 2006 | 07:31 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
I think his name is irockid on tgo, I saw him at the local track with his 350. He was running 100 shot, said he ran it a long time with no problems. I think he said he had run a 150 too, that or he was going to 150. I asked him a lot because at the time I planned a nitro setup, so I was curious.
Old Feb 6, 2006 | 10:44 PM
Car: 1986 Z28
flippin awesome man thanks for all of your help
Old Feb 7, 2006 | 12:21 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
2 degrees for every 50 hp is pretty safe, you should be able to get away with 100 hp on 0 timing retard or 2 degrees to be safe. Go with what the kit manufacturer recommends though.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
FlyinLow89
Nov 12, 2001 02:35 AM
vortech305
Mar 30, 2001 12:21 PM
