alcohol injection
Old Apr 1, 2006 | 12:03 AM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
alcohol injection
i did a search and found only minimal information.......
i'm pretty sure i want to use a good heavy alcohol mix for my f1r blown 383.......this is going to be just shy of 30psi someplace at max blower RPM i believe......my goal is to make 1000hp, and be safe (reasonably lol) while doing it.
just wondering what kits, homemade and purchases people were using and what seems to work best as far as a mix.....and if anyone found an advantage to using straight methanol (which i can get by the drum very cheaply).....although it does eat rubbers seals for breakfast.
Old Apr 2, 2006 | 07:20 PM
head's Avatar
Car: 1984 MSE #52
Transmission: TH700
TRY THIS LINK LOTS OF GOOD INFO www.members.***.net/stevemonroe/AlcoholInjMod.html
Old Apr 2, 2006 | 08:09 PM
JBert's Avatar
Car: Looking
Having previously sold theres on a retail level, check out Aquamist.
I believe the website is www.aquamist.co.uk
Really tough product, works really well.
I'll be using it myself with the blower set up.
Old Apr 2, 2006 | 10:32 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Take a look at these three:
www.smcenterprises.com
www.coolingmist.com
www.alkycontrol.com
I've never used any sort of alcohol injection kit scince I bracket race and dont need another variable to worry about but have heard good things about those three.
HTH,
Steve
Old Apr 16, 2006 | 06:35 PM
TA88GTA's Avatar
i have used the alky control kit on my TA, my grand nash, and installed it i and three other vehicles. I only have experince with that brand of kit but its got me hooked and i recomend it to everyone. The owner of the company is super friendly and extremly helpful. You can check his stuff out at Alcohol injection | Alcohol injection systems | DIY alcohol injection kits.
I myself have running 27psi on the nash with straight methenol and pump gas. No problems yet.
Old Apr 19, 2006 | 09:46 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Engine: Forged 350 with D-1SC
I am using the SMC kit on my supercharged TA and find it to be an excellent set up.
Old Apr 20, 2006 | 01:46 PM
Bill87GN's Avatar
Alkycontrol is the way to go! Although Mease is coming out with a trick new kit too
Old Apr 20, 2006 | 11:50 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
I use smc easy to hookup
Old Apr 21, 2006 | 10:05 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
It seems that everyone had an easy time hooking everything up. Do any of those kits actually have a pump that has seals that are designed for methonal or alcohol? None of the sites say that they support it.
Old Apr 22, 2006 | 08:54 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Yes. Julio Don at alkycontrol.com replaces the original pump seals with methanol compatible seals.
Julio (aka Razor) is a tech advisor at turbobuick.com and wrote the following article. He knows his stuff and I wouldn't buy from anyone else:
TurboBuick.Com - Tuning the Alkycontrol kit
Willie
Old Apr 24, 2006 | 12:31 PM
TA88GTA's Avatar
Wille beat me to it. Julio's pump are fully compatable and beleive that snow performance has also designed a new pump fro methonal.
Old Apr 24, 2006 | 09:22 PM
89ta383sc's Avatar
Car: 89 ws6 trans am
Engine: 383 supercharged
Transmission: t-56
Axle/Gears: 9 inch 3.90's spooled
I have put a kit together for my car. The reason is that alot of the kits are not big enough. My kit is staged and and I have alot of control over the jets.
It depends if you can have the chip turned to your car. I have over a grand in my setup. If you want to talk to someone that knows alot and makes custom kits, call and ask of George at (816)333-6582.
Old Apr 24, 2006 | 09:38 PM
antoine's Avatar
smc has the upgraded pump
Car: '91 Camaro RS
car is carbureted, its not that complicated for me lol
Old Apr 25, 2006 | 08:04 PM
3rdGenBlackBird's Avatar
DevilsOwn Alcohol/Water Injection is another place to check out. Great guys to deal with.
Scott
PurelyPMD
May 5, 2016 04:57 PM
NZKnight
Oct 15, 2015 02:47 PM
BAMiller
Sep 14, 2015 06:38 PM
TheExaminer
Sep 6, 2015 11:40 PM
