NOS on a L69
Old Oct 15, 2000 | 04:23 PM
84taL69's Avatar
NOS on a L69
I have a 84 HO Trans Am with the L69. The car has 98,000 miles. i have accel cap rotor and coil and have put a double roller timing chain in. I am wondering if the motor will be able to withstand Nitrous. If so what is the max i should run. Thanks.
1/4 mile: 14.81 @ 92.4
edelbrock headers and y pipe, dynomax cvx
Old Oct 15, 2000 | 10:35 PM
Cosmik Debris's Avatar
I think most people would advise you not to go much above a hundred shot. I have an L69 as well and mine runs almost identical times to yours. Mine has 130,000 on it. I put a NOS kit on mine I used a 37 nitrous jet and a 35 fuel jet. It ran 14.027@101.2
Cosmik Debris
Old Oct 16, 2000 | 11:27 AM
84taL69's Avatar
What all do you have to upgrade for to add nitrous? Your setup uses a plate under the carbb right? how does that work with the hood clearence? thanks again
Old Oct 16, 2000 | 03:07 PM
You don't have to do anything out of the ordinary to put nitrous on your car. Just make sure you have enough fuel pressure to maintain about 6psi and make sure your spark is good. I managed to fit the NOS plate and an Edelbrock RPM manifold with a drop base air-cleaner under my hood. I have the same car as you (an '84) the power bulge hood gives you a bit more clearance.
Cosmik Debris
Old Jul 5, 2003 | 12:51 PM
kamaroirock's Avatar
Car: 02 z28, 03 wrangler sport
Engine: ls1, 4.0L
Transmission: t56, 4speed auto
how much does that setup cost for the 100 shot for the L69 and were did u get it from? i might be looking to that. Cosmik Debris is your car a auto or 5-speed and what gear do you have in it?
Old Jul 5, 2003 | 01:06 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
NOS snipers for quadrajet cars is like $369 ?
Old Jul 6, 2003 | 08:12 PM
BillZ28's Avatar
Car: 84 Z28
From what I've seen, a 100 would be good for the streets, and if you want the most you can absolutely safely put on an engine, then I'd say a 150 shot.
Old Jul 16, 2003 | 05:00 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
hey Cosmik Debris:
how big of a drop base air cleaner do you have and where did you get it?
i have a RPM intake that im gonna have to put a q-jet adapter on so it will work and i will most likely need a drop base air cleaner.....thanks
junior419
Apr 7, 2025 11:35 AM
PurelyPMD
May 5, 2016 04:57 PM
Night rider327
Oct 13, 2015 01:47 AM
leighgrils
Oct 9, 2015 09:38 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
