What ring gap should I run with 6-8psi boost?
Old Dec 1, 2000 | 07:52 PM
Jester's Avatar
Cast rings and pistons....right now they seem to be about .009-.010...good?
Old Dec 2, 2000 | 11:17 AM
ede's Avatar
ede
the standard rule of thumb is about .003 for every inch of bore. i look at the manual and usually split the high low. if you do anything that generates more heat you'll want wider gaps on the top ring to keep the ends from butting up. you also want a tight gap to prevent excessive blow by.
-=ICON MOTORSPORTS=-
1st & 3rd
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
86White_T/A305
Aug 17, 2015 12:16 AM
TreDeClaw
Aug 14, 2015 06:58 PM
TheJoeY88
Aug 13, 2015 06:51 PM
BBSDesigns
Aug 11, 2015 07:39 PM
