Got my 2 turbos at a yard..ID help needed.
Old Dec 3, 2000 | 12:31 PM
Jester's Avatar
What exactly do I have...and will they be good for my application?
I got the first one out of a Mercedes 300D turbodiesel. I assume that meant it was a 3liter...but I couldn't find anything identifying that for sure. It says AIResearch on the exaust part..but not much on the intake part. Just G1L, with a 4 under it.
The other is out of a Dodge Daytona..and says Garret A/R .47 in it.
Both spin freely, quietly..and seem to be in good shape.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
Jesters's Page of Sick Pleasure
Florida Thirdgenners Message Board
ICON Motorsports
Old Dec 7, 2000 | 03:03 PM
RobO's Avatar
Search the mini mopar pages for ID help on the chrysler turbo, You should be able to find specs, pics, etc... that will help you identify it
You're on yer own with that Mercedes turbo
Rob_O
Old Dec 7, 2000 | 05:18 PM
Jester's Avatar
Yeah,. I was able to find stuff on the Chrysler turbo, but I'm still stumped on the Mercedes. I've found out it's a garret T3 or equivilent, but the AR is a mystery
Old Dec 7, 2000 | 10:02 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Hmmm... I dunno how to get more info on the benz turbo, but the Daytona turbo is pretty small. That .47 ar will probably let ya hit 10 lbs of boost at 1500-2500 rpms T3's are a fairly common turbo, but a T4 would be gold for ya. It's a bit larger (methinks) and very common for aftermarket turbos, so once ya work the bugs out of the low-buck turbo setup and go hunting for GT1 Porsche's, you'll be able to swap in a properly matched turbo. Just my few pennies
Andris
Z28tt-89 IROC T56 DFI Twin Turbo
Wolf-2000 Bright Platinum Dodge Durango R/T
(stock, for now. Bwah hah hah!!!)
Old Dec 8, 2000 | 06:49 AM
Jester's Avatar
Well for now 10lbs is about all my motor can handle later on, when I have a forged bottom end and can run more boost, I'll go looking to upgrade
Old Dec 11, 2000 | 10:22 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
What I meant is that you'll have 10 psi at idle The exhaust is pretty small, so you'll have those turbos overspooled very quickly. I don't think you'll be able to find a wastegate large enough to keep it at 10 psi at 5000 rpms. It'll probably be 30 psi, he he he. Don't forget that a good rule of thumb for non-ideal perfect mandrel bent turbo exhausts with big turbines, you'll have roughly 2x the backpressure compared with boost. So your 20 psi turbo is 40 psi backpressure.
A.
Old Dec 12, 2000 | 06:39 PM
Jester's Avatar
Ahh..I see what you're saying. Is there some sort of valve I can put on the intake pipe to bleed off extra boost?
Old Dec 12, 2000 | 10:15 PM
mike88RS's Avatar
jester, just out of curiosity, what were yourplans for the turbo? obviously for your car, but how? my buddy has a few of those things laying around(has owned 5 daytona turbos, including a shelby.(what a joke, like the "IROC")anyhow, just wondering your plans, if you wish to divulge your evil secrets, and ill see if hell donate a few to experiment on
thanks
mike
Old Dec 13, 2000 | 09:56 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Yes and no. If you run a pop-off valve like in IRL/CART/F1, it's all or nothing. Once it opens, it basically dumps all your boost. I guess you could figure out a way to modulate it with a soleniod and pulse control. The best way would be to have a bigass wastegate that can bleed off enough volume. If you do go with the small turbo, and bleed off the intake, your backpressures will still be astronomical (since the turbo is still putting out just as much air as previously). For hacking around, I'd say just go for it and experiment. So what if its not perfect. If you see it overboosting, just let off the gas. What I did with my setup was to set the fuel map to full rich - i.e. 100% injector duty cycle once it hits 9 psi. I have my Deltagate wastegates set at 5 psi, and on a cold day, it will overboost a lot. The super-rich mixture makes the car fall flat on its face, and is a safe way for me to know "GET OFF THE GAS!" before I pop holes in the cast pistons. I'm wrapping up the intercooler install and 9" rear, so I should be able to raise the boost a little without detonation. We'll see
Andris
Old Dec 13, 2000 | 10:04 AM
Jester's Avatar
Well...the plan is to use twin turbos on my carbed 350 that will be completed soon. I bought a set of S10 v8 conversion headers I'm gonna do some cutting/rewelding on, flip upside down and hang the turbos off the end of with some adapter pipes. They'll be a header collector on one end, a turbo flange on the other, and whatever shape pipe I need inbetween to locate the turbos where they will fit. I havn't decided if I'm gonna make or buy a hat for the carb. After that it's just a bunch o pipes I need to route. Well..thats pretty much the plan in a nutshell.
Right now I just have the turbos I posted about, but if your buddy has some that would be better suited, I'd be much abliged.
JSP Motorsports
ICON Motorsports
Old Dec 13, 2000 | 10:08 AM
Jester's Avatar
I'm running cast pistons too Since I'll be carbed, running on the rich side is easy too
Andris, do you have ICQ? If so, my number is 9112495...I'd love to get some pointers from ya.
JSP Motorsports
ICON Motorsports
Old Dec 13, 2000 | 11:49 AM
mike88RS's Avatar
JESTER, Ill try to get one or two for "experimental" purposes, ill throw them at you to fool with if I can
nothing better suited though., they are all pretty much stock, with a little adjustment to a 4cyl advantage
mike
Old Dec 13, 2000 | 12:47 PM
Jester's Avatar
That'd be great man, I'll take whatever parts I can I'l be near Tampa sometime in the next month or so too, I could probably pick them up.
JSP Motorsports
ICON Motorsports
Old Jan 3, 2001 | 01:31 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
hey mikeRS, i'm in melbourne FL at school, but i have a 88 daytona shelby Z in NY that i drive in the snow, if u brother knows alot about them, could u give me his e-mail or something, damn thing is a pain in the *** , but i know if i could get it to work they're fast. my e-mail BMX15x@aol.com thanks
cheesehomer
Dec 31, 2015 08:48 AM
bjpotter
Oct 4, 2015 07:48 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
bschmale66853
Sep 30, 2015 08:11 PM
efiguy
Sep 27, 2015 01:30 PM
