Nitrous oxide with stock bottom end 305
Old Jan 27, 2001 | 07:08 AM
DownUnderIROC's Avatar
Hi guys, I plan to add nitrous to my 305. It's got a stock bottom end with a Mellings HV oil pump, ported stock heads, small crane cam etc. Best ET is as per my sig.
What is the maximum nitrous shot that I can *safely* add? Is a 100 or 150 HP shot too much for a stock bottom end 305?
I plan to upgrade my fuel supply with a Vortech T-Rex inline pump, b4 running the N2O.
Any opinions? Thanks
1987 Chevy Camaro IROC-Z. 305 TPI. 700R4
14.6 secs @ 93 MPH.
2.14 sixty foot.
Homepage
Old Jan 27, 2001 | 07:28 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Jim,
Tim Burgess has been running a 90 shot for years on his stock-bottomed 305. We both know how hard he drives his car at the track.
Here is my hypothesis on how much nitrous you can use: Tim runs low 12's with a 90 shot. Tim's car is unique in the sense that he runs high 12's naturally aspirated. I don't know of any other 305 that can make this claim. I for one, do not come close. So he definitely has a huge head start. A given amount of stress is induced on the engine (bottom end) when running low 12's. Unlike Tim's car, it will most likely take much more than a 90 shot to equal his times. However, the stress induced on your bottom end will be the same as in Tim's car, given the same end result (low 12's). Therefore, I firmly believe that you will be able to use even higher levels of nitrous in order to get your car down into the low 12's.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://members.optushome.com/au/downunder1/rides/willie/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
[This message has been edited by Willie (edited January 27, 2001).]
Old Jan 27, 2001 | 04:45 PM
RacinLT1's Avatar
I have a 127k mile 305 in my 91 TA. Last season we were running a 120 shot to it and made a best pass of 12.38@108,and we had it jetted WAY too rich.With tuning i believe we can knock another 1/10 or 2 off.Also I tried hitting it with a 160 sgot,and it ate the clutch.
This year i am going to install shorty headers/3" cat back/3.73's/new clutch. Hoping to get into the 11's with the nitrous,and I really dont think ill have a problem.On motor it ran a best of 13.44,the car has a LOT of wieght removed(the only reason i can figure out it does run so good).
Dirk
1991 TA WS6 305/5 spd
Nitrous,hooker shorties,flowmaster 3" cat back,3.73's and a 160 shot of nitrous
DragStars 15x3.5 et fronts,15x10 rears with 275-50/15 BFG DR
1997 TA LT1
Draglites,15x3.5 sportsman pros
16x9 255-50/16 Comp TA's or Drag radials
Moroso CAI,no sway bar,dynomax non catback
Old Jan 27, 2001 | 05:37 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
I've seen from some sources that a 125 shot is about the highest you want to run on a stock 305. *Don't quote me on this though!*. Make sure you get a throttle switch or a nitrous computer like the Jacobs Electronics Nitrous Mastermind to help prevent any problems.
Old Jan 27, 2001 | 11:15 PM
camaroracer1992's Avatar
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
I have a 125 shot on my 305 TBI and have gone through approx 10 bottle fills by now and have not had a problem. Just make sure you run colder heat range plugs and maybe retard the base timing a couple of degrees.
Old Jan 28, 2001 | 08:14 AM
Nitro Don's Avatar
I have run 150 hp plenty of times.Iv'e even steped up to 175 hp now.The two most important things to remember are timing and fuel.
When I get this thing tuned right,(heads flow like ****)I should be in the mid 11's.
Then I'm going to see If I can be the first around here to run 200HP in a stock bottom
305.Maybe
1990 Trans Am WS6
305TPI 700R4
ENGINE:
150hp NOS kit
March underdrive pulleys
Edelbrock headers(JetHot)
Mac off-road pipe
Flowmaster exaust
Jacobs ultra coil
K&N filter
Fulley ported base,
runners,& plenum
Crane AFPR
Hypertech airfoil
Crane 1.6 rockers
210/220 .533/.544 Cam
W/P Torquer heads
Edelbrock TPI Base
Edelbrock TI Runners
Edelbrock 52mm T.B.
TRANSMISSION:
Richmond 3.73's
Auburn posi
B&M Mega shifter
B&M Transpak
Vette servo
B&M 2400 converter
TCI Trans Rebuild
Nitto Drag radials
FUTURE MODS:
The 700R4 is DEAD!!
Neeed to rebuild AGAIN!!
BEST RUN:
12.48 @ 109.23 MPH
(with stock heads,cam,intake,and crappy Pep Boy's tires)
Old Jan 28, 2001 | 08:29 AM
Thanks for the replies
Willie, I agree with your post re 305 bottom end. 12's should not be a problem, based on Tim's and your own experience.
Nitro Don, you have some awesome times there for stock heads and cam. Now I am worried about my 700R4! I think the trans may be the weak point for 12 sec passes. My trans was rebuilt 1.5 years ago, but it is stock.
Old Feb 7, 2001 | 01:17 AM
big tex's Avatar
<font face="Verdana, Arial" size="2">Originally posted by camaroracer1992:
I have a 125 shot on my 305 TBI and have gone through approx 10 bottle fills by now and have not had a problem. Just make sure you run colder heat range plugs and maybe retard the base timing a couple of degrees.</font>
What is the kit number for the NOS for a TBI...I would really like to know.
Old Feb 7, 2001 | 10:58 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
05153 (A,B)GM TBI, throttle body injection, 4.3L V6, 5.0L & 5.7L
05153-V6 (A,B)GM TBI, throttle body injection, 2.8L V6
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
Club IROC-Z
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Mar 5, 2017 06:37 PM
kyleb24
Aug 15, 2015 08:24 AM
Leggman1
Aug 6, 2015 04:15 AM
