nitrous explosions
Old Mar 11, 2001 | 12:22 AM
james_fearn's Avatar
nitrous explosions
well here's a link from my mustang days. I don't know if u guys have seen these pics before...
http://www.enhancedhealth.com/NOS2.htm
James
1985 Z-28 305 TPI
221,000+ mi., Original Eng.
Old Mar 11, 2001 | 01:21 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
From what I've heard, he had taken apart the pressure relief blowdown valve, and added several rupture discs to prevent possible premature venting. This disabled the blowdown rupture valve, permitting the bottle to exceed its pressure capacity and explode - nothing to do with the safety of nitrous, just an individual user's stupidity.
A.
PS-like everything else concerning this explosion, this is from rumors and word of mouth.
Old Mar 11, 2001 | 01:33 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Yeah I've seen that one before. What a mess!
I always wondered about it. Sometimes people accidently put in two rupture discs in the blowdown tube instead off one. They are thin and can stick together so it is easy to do. Also if it is bent or creased that can strengthen it. I wonder if any of these things are what caused it not to blow off.
I also wondered what caused the bottle to build that much pressure. I would assume it was heated by the bottle heater. Failed relay could cause it to stay on. I use two relays in series for redundant protection. If one fails and closes the contacts the other will still stop current flow. I also put a plug in the wires at bottle heaters and only have them pluges together when at the track or when planning to use the nitrous. When I open the bottle valve I plug the wires together and when I shut the valve I unplug them. I might be a bit paranoid but I don't want my ride peeled open like a Dole banana. LOL
Also for a little more peace of mind, I use fusible links at the battery for my bottle heater and solenoid supply wires. That way if something shorts I don't have a glowing wire catching something on fire.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
Club IROC-Z
Old Mar 11, 2001 | 03:12 AM
Omar's Avatar
As the story (rumor) goes on, it was the bottle heater that built up the pressure to begin with. He had supposedly wired the heater to a CONSTANT 12V source, instead of a switched ignition source. Another stupid mistake. I think I read that he accidentally hit the switch while cleaning his car, or getting something out of it. His supposed 3rd mistake? You would have thought that the thermostat would have done its job and turned off at 85 degrees, right? It would have...if he hadnt removed it.
Like said before...all rumors.
1989 IROC-Z 5.7L
Old Mar 11, 2001 | 08:32 PM
precision350's Avatar
Whatever the case may be, that boy deseves the "MORON OF THE CENTURY" award!!!
92 Camaro Z28
350 TPI
Dart Iron Eagle heads
10.5:1 cr
Lunati L54779 cam
52mm throttle body
Ported plenum
Home made AFPR ($2)
1 5/8 shorty headers
Ram air
255 lph Holley fuel pump
2.5 inch TRUE DUAL exhaust (no cats)
Flowmaster mufflers
4.10 gears
700R4 w/2000 stall
100HP nitrous
Best time before any of these mods:
15.1 @ 91.9
Best time after mods:
12.60 @ 108.3
That is at high alt.
5600 feet Morrison, Colorado Bandimere Speedway
Old Mar 21, 2001 | 12:05 PM
vortech305's Avatar
I was thinking about getting nitrous awhile back damn that my mama didnt raise no fool procharger here we come.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
tyeo098
Nov 30, 2015 06:27 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
johnsjj2
Carburetors
Aug 7, 2001 10:59 AM
