Best head for a blower/ported TPI setup and 17lbs of boost
Old Mar 21, 2001 | 03:34 PM
89ProchargedROC's Avatar
well i've been looking around and have found a few i like. so far my choices are:
AFR 190 or 195
Canfield 195
Brodix special edition heads
so far i really like the brodix, i have to find out price first. they dont flow a whole lot on the intake but flow mass out the exhaust which is important for blowers. also it has a 187cc intake port which would help velocity and power with the ported TPI setup.
would appreciate all opinions and any other heads you can reccommend. here is the link to the heads:
http://www.canfieldheads.com/sbc_2500.html
-i like the price and intake flow on these and the exhaust would wake up with some minor porting
http://www.brodix.com/Catalog/Heads/...p_sy_wt-1.html
-these i think would work awesome, only problem is that they are already fully ported so no room if i do something else
www.airflowresearch.com
seem good but need to wake up on the exhaust and a little more expensive than canfield
update:
forget about those brodix heads....like $2800 screw that
[This message has been edited by 89ProchargedROC (edited March 21, 2001).]
Old Mar 21, 2001 | 04:47 PM
Bob Wooten's Avatar
I dont know if you are intersted or not, but check these out. this is a friend of mine & i was considering buying the heads, but thought that a ATI would be a better purchase He is a Machinist & does all of his own machine work (not porting stuff though). if you want to know more info contact June (his wife) or get me off list & i will fill you in.
BW
http://www.elevenoclock.com/cgi-bin/...001-000000.msg
Bob Wooten
r71chevy@earthlink.net
www.r71camaro.homestead.com
Old Mar 21, 2001 | 07:40 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
I like the dart II sportmans on mine i had
a few pistons give onder the strain and was
glad that the iron was there if not the piston
ring that took off too would have goudged
allumin heads. and if your wondering i did
have the rings gaped for supercharger/nos.
most of my problems were with making my timming
too aggressive and thainkig i could get away
with it running race gas.
Old Mar 21, 2001 | 07:41 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
check out my simple page at:
http://darcom.home.texas.net/
Old Mar 21, 2001 | 08:57 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Pro - like you mentioned, you need exhaust flow. One of the third-gen email list folks (Terry Hartman) had AFR cast a custom head using the 195cc intake runner, and the exhaust runner from the 210cc head. He's happy with it AFAIK.
I'm going through the same dilemma right now too - I'm leaning to the AFR's as well, with the big exhaust port since the turbos add tons of backpressure. The Canfields look nice, but don't look like they have the same flow numbers. I don't know a good shop to have them ported, so the AFR CNC's look appealing. What about the Trick Flow 23 deg heads? I'm most concerned about flow movement to kill detonation, rather than ultimate flow. Any ideas? I've got to find some sodium filled valves now, and will have the combustion chamber coated.
A.
Old Mar 21, 2001 | 10:09 PM
<font face="Verdana, Arial" size="2">Originally posted by askulte:
A.
</font>
i wonder what that ran him to that custom head? also, i'm leaning more towards the AFRs because if i ever need to sell them...they have a proven name and wouldn't be hard to sell. With the canfields, not a lot of people would bite because of the EGR...i think i might talk to larry at ASSC and see what he's running in his formula...i think they are AFRs.
Old Mar 21, 2001 | 10:26 PM
vortech305's Avatar
Take it from me Brodix
Old Mar 21, 2001 | 11:56 PM
<font face="Verdana, Arial" size="2">Originally posted by vortech305:
Take it from me Brodix</font>
would you like to explain a little bit?
i like the Track 1s but heard that the port is too high for the TPI base. Also, that intake port is kinda big. like 215cc, i'd just go canfield 220cc instead.
Old Mar 23, 2001 | 07:56 AM
Blockhead's Avatar
Take it from me, ported 305 heads.
"Powertuned"
83Z28 w/ 434 SBC
589.2 rwhp/648.4 rwtq
best mods? Vericom 2000
Director of Darwin Awards @ www.thirdgen.org
Old Mar 23, 2001 | 01:40 PM
this isn't the the loungepeople. cant we just keep one topic that doesn't go off track?
keep the opinions coming.
Old Mar 25, 2001 | 02:22 PM
vortech305's Avatar
well i was given this opinion from this guy dave who's corvette's have been in car craft or was it hot rod and runs 9' and using very simple work on his motor and uses stock exhuast manifolds. I saw some of your mods and mentioned it to him and he said to order the brodix and if possible get a 52 mm throttle bodie and a mini ram of course if your running fuel injection.
Old Mar 25, 2001 | 03:34 PM
well, i dont want to use a mini ram because of its fuel distribution problems and am either going to use an accel pro ram or use a ported TPI setup. I think for some stealth look i'm going to keep the TPI setup.
i think i've decided on AFR 195cc
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
BBSDesigns
Aug 11, 2015 07:39 PM
squiggy2
Aug 9, 2015 09:30 PM
