NOS(200)+300hp 305TPI = WOW 500 hp 305 TPI
Old May 1, 2001 | 01:05 PM
vortech305's Avatar
With my mods that i have done to my 305 TPI, im plenty sure i should be making 300-330 hp or more naturally aspirated(at the cranck of course). If i add a 200 shot on nitrous the hp level should be outstanding for a 305 even though im sort of cheating by using NOS. WOW im exited cant wait to blow doors off of mustangs thos annoying imports and some (hmmm) 350's . Cant wait to show people at my local dragstrip what a puny 305 can do. DOnt worry i have the suspension and slicks to take care of the traction.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old May 1, 2001 | 01:41 PM
Formula-91's Avatar
Just make sure that your rotating assembly can take that big of a shot. If the pistons, rods, and crank are forged, go for it. If not, you might want to rethink the size of the shot.
Old May 1, 2001 | 04:26 PM
vortech305's Avatar
Everything is forged and costed $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ but well worth it.
92' camaro
Soon to come!!!
Other car;
Old May 1, 2001 | 08:36 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Don't be so confident about the stoutness of your motor. You're already using a supercharger so the cylinder pressure is pretty high. Hit it with a 200 shot of nitrous (which will fall short of 200 shot on a 305) and you will make the cylinder pressure go sky high. To make things worse, the nitrous shot will actually be more potent on the supercharged car then on a N/A car. This is becuase the nitrous will significantly cool the air charge to the motor and the blower will make more power for you. Once again, more cylinder pressure. I would expect your head gaskets to blow.
But telling you all the negative things here wouldn't help you much, would it? So here's the positive. You basic idea to use nitrous with the blower is really good. But you really need to tone down the power level. The whole advantage of using the nitrous with the blower is it will cool the air better then an intercooler. Just use a mild 75 Hp shot and you'll get waaaaaay more then 75 Hp because the blower will make your motor come alive . Now just have to figure out how to dump a ton of fuel in there when the nitrous is activated.
[This message has been edited by QwkTrip (edited May 01, 2001).]
Old May 1, 2001 | 08:39 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Whoops, I just noticed you have a T5 tranny too. That will end up exploding.
Old May 2, 2001 | 12:01 PM
vortech305's Avatar
JUst got a richmond 6 speed that i plan on installing. IF u see on top of my sig u can see future mods. I dont have the blower yet. $3,000 dollar for a blower than $400.00 for installation, i decided just to get nitrous. Besides my compression is 9:6:1 blower wouldnt do much good, so ill go with 200 shot of nitrous. I only plan on using the nitrous on weekends and maybe on some cruising roads
Old May 2, 2001 | 12:56 PM
Blockhead's Avatar
Hey do you think if I put a 200 shot on top of my car, it would make any difference?
91 Formula
Twin turbo
1156.4 rwhp
8.45 @ 171mph
Director of Darwin Awards @ www.thirdgen.org
Old May 2, 2001 | 01:38 PM
Matt98SS's Avatar
nice to see somebody with some brass
I would recommend a window switch connected to the solenoids or WOT switch just in case
good luck!
Old May 2, 2001 | 02:38 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Damn right, who says a 305 can't boogie. just make sure you jack it up like a mother before you go prowling for rustangs.
And blockhead, i don't think nitrous is gonna help you much, with a 171mph trap speed you'd really need a 3 stage IHRA pro mod set-up to really dig in off the top.
Old May 2, 2001 | 04:48 PM
vortech305's Avatar
Anyone got any guesses what my torque would be with my mods and 200 shot of nitrous. I would prefer to know the torque at the crank or Rear wheel if possible. Any gueses
92' camaro
Soon to come!!!
Other car;
Old May 2, 2001 | 05:20 PM
The ODB's Avatar
200 horsepower @ 3000 RPM = 350 lbft of torque.
200 hp @ 5252 RPM = 200 lbft of torque.
I think you could've figured this out yourself.
jack it up like a mother (tm*)
Old May 2, 2001 | 08:38 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
And one more thing... jack it up like a mother.
Old May 3, 2001 | 08:47 AM
vortech305's Avatar
Old May 3, 2001 | 03:33 PM
Killer-Z's Avatar
"T-5 tranny"-better get rid of this!! Derrick
Old May 3, 2001 | 06:40 PM
vortech305's Avatar
uh i said i have a richmond 6 speed
92' camaro
Soon to come!!!
Other car;
Old May 8, 2001 | 10:29 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Gad Damn it people, he said he had a Richmond. Don't worry Vortech, I'm listening.
How fast are you running naturally aspirated?
Rob
1987 IROC-Z Auto (LB9)
Black/grey interior with the stance of a streetfighter
I like to think of her as Arnold Schwartzeneger in a dinner suit
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat. K&Ns, AFPR and Air foil.
Future mods:
Cam change
New torque converter
New heads (maybe corvette L98)
Strut brace
Sub frame connectors
Ram Air
Current G-Tech times
0-60mph 6.26 seconds
1/4 14.74@100.2mph
Old May 9, 2001 | 08:31 AM
Matt98SS's Avatar
man his set up is JACKED UP LIKE A MOTHER already!
any testing with the 200 shot yet? What is your fuel system like?
One more thing I would dump the Bosch Platinums for some copper plugs at least 1-2 steps colder
Old May 9, 2001 | 10:08 AM
vortech305's Avatar
yeah i know all about that changing plugs and timing. Didnt get the nitrous yet, like i said its gonna take till june or july hell i havent even broken in the damn motor yet. Ohhhh i cant wait to test it out, I was told by many publications and other sources that i should be making 320-340hp on the crank. Adding the 200shot of nitrous what do u think my 0-60 and quarter mile time are. Any GUESSES, i have the suspension taken car of, oh and some slicks . I talked to NOS and they said i can use stock fuel lines and just order there fuel pump and i should be fine. Im getting autolite spark plugs
Old May 9, 2001 | 01:23 PM
Matt98SS's Avatar
should be WELL into the 11s if you can hook it good and shift well! Keep up informed
Old May 9, 2001 | 05:26 PM
vortech305's Avatar
Oh i will, i will MAn 11's on a puny 305, IF theres a god hopfully with the right tunning, Awesome traction and right shifting i can ehhmmmm maybe hit hi 10's...... I bet the big blocks and fords will be .
92' camaro
Soon to come!!!
Other car;
BlueIroc-Z
Jun 9, 2019 03:22 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
69 Six Pack
Oct 5, 2015 07:51 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
