What do yall think of this blower-engine combo>
Old Jun 2, 2001 | 11:01 PM
sslee's Avatar
I have a 355 with TRW forged 21cc blower pistons and total seal rings, trickflow heads,and a 144 B+M blower. I will try to pulley the blower for around 6-8psi. The compression ratio is around 8.5.
I am not sure on what cam to get yet, thinking of something with a 2500-6000 rpm range.
Old Jun 2, 2001 | 11:07 PM
sslee's Avatar
What hood do I need to cover up the huffer?
Give me some ideas on a hydralic cam?
82z28 (currently building)
70.5 camaro
383 with D-2 procharger
best time 9.38@148
Old Jun 3, 2001 | 02:46 AM
89ProchargedROC's Avatar
go with a quality ring set for one, dont need the sealed rings.
they create A LOT of pressure in the cylinder walls and the extra 5hp they give you can be found elsewhere
Old Jun 3, 2001 | 11:59 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
<font face="Verdana, Arial" size="2">Originally posted by 89ProchargedROC:
</font>
If you listen to him, youre gonna lose about 40 hp down past the ring gaps into the crankcase as blow-by. Do some reading up on the Total seal gapless rings and ask some people who've actually used them. In fact, E-mail my buddy who drives a 86 Buick GN with Total Seal Gapless rings. He'll tell you how good they are. He can be E-mailed at cl3gnturbo@aol.com.
As far as the cam goes, you dont wanna have too much overlap. What do you plan on using? Roller or flat tappet? Let me know and I'll check into it for you.
Dont use gapless rings? HA HA HA HA HA HA HA HA!
BTW 89ProchargedROC... You said that the gapless rings create too much pressure in the cylinder walls? Are you refering to friction? Well guess what? They make a low tension oil ring set to reduce friction losses, but they let a weee bit more oil get past the piston into the chamber. Ummm... the gapless rings dont add anymore friction or "cylinder wall pressure"(isnt that what you called it?) than a standard set of Speed Pro file-to-fit rings. If you think they do, I'd like to see you prove it. Dont flame me like you did in the message board over at CamaroZ28.com. Show me proof, oh god of forced induction!
DF's and IB's... lord help them!
[This message has been edited by JAYDUBB (edited June 03, 2001).]
Old Jun 3, 2001 | 03:04 PM
i'm not flaming you.
this information comes from one of canada's best engine builders
speedway racing
that is what he told me and he has built more 8 second cars then me and you ever have
Old Jun 3, 2001 | 05:30 PM
mtx28's Avatar
easy there, jaydub
  • 83 Z28-- not a pretty site to look at, 200k miles and im sure it was treated like a rental car every day of its sad life(before i got it).. sold, thank the lord
  • 74 Z28-- 383/400, green on black. pretty clean. FOR SALE!!!
Old Jun 3, 2001 | 07:06 PM
sslee's Avatar
I am going to use the total seal rings. I use them in my 70 camaro with a D-2 with no problems.
I want to use a hydralic flat tappet in my 82. Any sugestions?
70.5 camaro
best time 9.38@148
Old Jun 3, 2001 | 11:41 PM
just curious...what does your 70 camaro weigh?
thanks
Old Jun 3, 2001 | 11:54 PM
sslee's Avatar
It wieghs 3310 lbs.
70.5 camaro
best time 9.38@148
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
roysatikas
Sep 22, 2015 08:15 PM
z28guy134
Sep 1, 2015 11:50 PM
