Think one of my turbos needs a rebuild..questions.
Old Jun 11, 2001 | 12:28 AM
Jester's Avatar
I've been having a problem with my new engine smoking like a ****. I was beginning to suspect a screwed up ring or something..but the thought occured that it may be a leaking turbo. Closer inspection revealed that the wheelwell where my one turbos outlet faces, is coated in a black oily substance, and there is even oil visible in the turbos outlet itself. Is it likely to be leaking oil into the exaust too, causing my problem?
Also..where can I get a rebuild kit, and how much should I expect to pay? Or would I be better off getting a new turbo? The shaft still spins freely..and it does spool up.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Jun 11, 2001 | 12:16 PM
Bobalos's Avatar
How old is/are the turbo's? It might be time for it. If one is doing it quite bad but the other not makes me think that there might be a problem with the drain line for the turbo. if the drain line has a blockage the oil has to go somewhere & it is going to be through the seal.
BW
Bobalos
aka Bob W.
www.r71camaro.homestead.com
r71chevy@earthlink.net
Old Jun 11, 2001 | 02:06 PM
Jester's Avatar
Both turbos are junkyard specials from the late 80's...so they hav some age. It's entirely possible that one of the return lines got a kink or something..I'll look at that closer today.
May still need a rebuild tho too.
JSP Motorsports
ICON Motorsports
Old Jun 11, 2001 | 06:12 PM
Jester's Avatar
I just went out and checked..and the offending turbos return line had shifted and gotten a kink in it. I replaced it..and it is smoking alot less..and took longer to start smoking. It may still be leaking to a lesser extent..or it may just take time for the oil already there to burn off. I'll have drive it more to find out...thanks for the tip.
I may still need to rebuild it tho..if anyone knows a good source for a rebuild kit.
JSP Motorsports
ICON Motorsports
Old Jun 11, 2001 | 10:46 PM
Twin Turbo 358's Avatar
my passenger side turbo is doing the same thing. i just took it off last weekend and will be having new seals put in. the return line did not seem to be blocked in any way. will let you know how it goes...
Jeff
99 T/A WS6 A4, RKSport lid & free EGR mod
88 GTA twin turbo 358, forged crank, forged H-beam rods, Wiseco reverse dome pistons, Dart Sportsman II 72cc heads, Comp Cams custom grind blower cam (.560/.586 lift, 232/236 duration), 1.6 roller rockers, TPIS mini ram intake manifold w/ Accel 58mm TB, 83 lb injectors, Accel DFI computer with variable injector controller, 2 Garrett T04B "hair dryers" with dual Garrett wastegates, TH400 tranny with BTE transbrake and Art Carr custom converter, F*rd 9 inch rear w/ 3.50 gears, and more...
Old Jun 11, 2001 | 11:28 PM
Bobalos's Avatar
Jester,
You might want to take the lines off of the turbo & see if the passage into & out of the turbo looks clear. I have seen pictures of "coked" up turbos that actually looked like they would restrict oil flow. if that is the case then it might still be restricting the flow out of the turbo even though once it is out it flow well. If that is the case you might need a rebuild anyway, so............. dont know.
I dont have a recomendation on the rebuild, possibly back to the mfg? Or it might be cheaper just to goto the wrecker & get another one.?.?.?
BW
Bobalos
aka Bob W.
Old Jun 11, 2001 | 11:39 PM
Jester's Avatar
well..my turbo just solved that. I just drove it around the block.....and halfway around the turbo started spewing oil...it's toast.
DEFINATLY needs a rebuild..at the very least.
JSP Motorsports
ICON Motorsports
Old Jun 11, 2001 | 11:59 PM
Bobalos's Avatar
Its midnight in Florida, how can you see it spewing oil, Im sure you can smell it though .
BW
Bobalos
aka Bob W.
Old Jun 12, 2001 | 10:18 PM
GMI FAST's Avatar
Old Jun 12, 2001 | 10:56 PM
Jester's Avatar
Oh wipe that stupid grin off your face. I knew going in thats the risk you take when you buy a junkyard turbo for $60. That, plus at worst $100 for a rebuiuld kit, is still better than any deal you can make I'm willing to bet.
JSP Motorsports
ICON Motorsports
Old Jun 12, 2001 | 11:23 PM
Bobalos's Avatar
Is that what the smirks are about? Spend another $60 & have a good time. This is not about who can spend the most money 'cause we all lose there, Leno & alen & Jackson have the upper hand on that, its about haveing a good time & playing with our toys, enjoy it, dont be a slave to it.
BW
Bobalos
aka Bob W.
Old Jun 13, 2001 | 12:06 AM
GMI FAST's Avatar
What the heck are you guys talking about? I was smiling at Bob's "midnight in Florida" remark. Damn, take a Zanex and smile, touchy-pants!
Old Jun 13, 2001 | 12:47 AM
Bobalos's Avatar
Zanex, is there something new that I need to go talk with my Dr. about? Cool.
BW
Bobalos
aka Bob W.
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
