Turbo vs Supercharger?
Old Jun 28, 2001 | 03:05 PM
92Camaro305TBI's Avatar
Which do you guys perfer and Why? I was looking at superchargers but seems like turbos are where the power is...
92 Camaro 305 TBI Automatic
2.5 high flow cat
2.5 pipes
3.5in tip
shift kit
Tinted windows(legal)
Spark plug wires and plugs...
Future mods.
Headers
O.E.
any other advise on getting to 300+ HP would be appreciated. Thanks
System = Sony explode 5000 CD/MD receiver
Rockford 6x9 Fanatics
Rockford 4x6 Fanatics
Rockford 2 12" Hx2's
Custom box
Rockford 1 farad cap
Rockford 800x2 Amp
4gauge wire kit
Old Jun 28, 2001 | 03:45 PM
Tas's Avatar
Tas
turbos are very complicated on v8s. a good old fashoned roots blower would be good for your TBI. they start at $1300 brand new.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Jun 28, 2001 | 03:53 PM
fast86's Avatar
One simple answer! TURBO's.
I had both a turbo 4 cylinder car and a 10psi paxton powered 350.
Lets just say the turbo car would walk over the supercharged 350. The main reason is the turbo power level is adjustable. If you want to fun 30 psi all you have to do is turn a ****. The paxton I was pushing it really hard just to run 10psi anymore and it would blow it up!
ALso turbos last longer then superchargers.
Turbos are cheaper to rebuild.
Minus is there is no good kits out there for our cars!
Superchargers kits are readly avalable!
If your inteasted try reading some books on turbochargeing to get an idea of what is involved in turbocharging you car!
Old Jun 28, 2001 | 04:13 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Get these books and make the decision for yourself...
"Turbochargers" by Hugh MacInnes
"Maximum Boost" by Corky Bell
"Street Supercharging" by Pat Ganahl
"Automotive Supercharging And Turbocharging Manual" by John D. Humphries
I've read ALL FOUR. Ive dealt with AND worked on vehicles equipped with Roots blowers, turbochargers, AND centrifugal superchargers. I'm a big fan of forced induction, and from what I can see (as you will see if you read these four books) turbos are the way to go! Even if it is expensive to get one set up properly, the power that can be made is well worth it!
Just my $0.02...
Old Jun 28, 2001 | 05:34 PM
BLOWN85/TA's Avatar
After having Turbo's and Blower's I would rather own a turbo system. The supercharger's are kits which installs without a HUGE amount or no fabrication. Turbo's are DIY type of things, so be ready to do all that it takes. Turbo's offer more HP at lower RPM levels and overall, while centrifugal blower's are hi rpm power adders. Turbocharger's are far tougher and last longer than centrifugals.
Turbo myth is one size allows for optimum boost at 10 and 20 PSI, not true. The turbo size has to be matched to the engine and the desired power curve.
I agree you should read up on the subject so you can make an INFORMED decision.
Old Jun 28, 2001 | 05:52 PM
I will, And thanks.. I was just wanding what you people though about it.. And also... Since im not sure about this stuff.. and you guys are right.. I might as well ask..
Friends tell me Turbos, Take exhust and suck it out as well as but it back into the system...
and well Ive seen a supercharger and basically it just forces air into the intake....
I KNOW THERE IS A LOT MORE THAN THAT..
if what people are telling me would it be possible to put both on a car??
I know its crazy and im going to get laughed at.. just wanding.. and ill get some books,,, Thanks guys...
Oh yeah one more thing.. anyone here have a Turbo on a third gen?
Old Jun 29, 2001 | 08:40 AM
B430's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 92Camaro305TBI:
</font>
a turbo is a centrifugal superchager driven by exhaust gas. it doesn't put any exhaust back into the engine.
Old Jun 29, 2001 | 09:04 AM
PROCHARGED89Z's Avatar
If you want to keep it simple go supercharger.2 motors built acordingly with either power adders,the turbo will have at most a 40-50hp advantage.Backpressure robs some but not alot of hp.If you want to drive your car anytime soon go supercharger.Drive either one if you can. A Supercharger is not a slouch at all,as some seem to make it when this comparison comes up.Take a ride in a 500hp supercharged car and tell me its doesnt do anything for you.But last but not least as with any combo,alot of matinence is expected,I hope anyone is not thinking,well put a turbo on my thirdgen,weekend project,30psi and go on my merry way.Far from the truth.The amount of cars,well to be more specific to your application,third gens running turbos to thirdgens running superchargers,tha ratio is at least 500 to 1.I have seen,and not in person only 3 turboed thirdgens.Best recommendation is a B&M 144 for your car now.
Check out my Hompage,or the beginnings of one.355 dynoed at 400HP at 5800RPM & 410LBFT of TQ,on Motorhttp://www.procharged89z.cz28.com/index.html
Old Jun 29, 2001 | 11:29 AM
Thanks for the info.. Im still going to read up and for some reason i would like to have my car turbo charged instead of supercharged. Is that b&m 144 a Turbocharger or supercharger. And where can I take a look at it..??
[This message has been edited by 92Camaro305TBI (edited June 29, 2001).]
Old Jun 29, 2001 | 04:05 PM
pimpintheRS's Avatar
the b&m 144 is a super charger it is a roots blower... you can find it in summit.. i think i might put that on my car i was looking at the ati procharger and the vortech supercharger which is belt driven as well but i think i might stick with a roots blower.. and nos maybe... you see more turbos on the imports usually until you get into the drag scene.. for some reason the 8's have more super charges available then turbos.. i am conteplating the same thing as you 92camarotbi same engine and all.. i plan on buying a supercharger in 6 to 9 months researching in the mean time...
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
New2Chevy
Sep 28, 2015 12:35 AM
-=Z28=-
Sep 24, 2015 10:21 AM
