Am I getting too much oil to my turbos?
Old Jul 8, 2001 | 02:43 PM
Jester's Avatar
Both of my turbos are out for a "they needed it anyway" rebuild. But I was wondering if using too large an oil supply line might have something to do with my leaking problem as much as failing seals. I'm running a 1/4" tube to a T fitting, then 1/4" tube to each turbo. My engine sees 60 psi..even when warmed up with 5-30wt.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Jul 8, 2001 | 03:29 PM
Biochem's Avatar
Car: 2002 SOM z28
60psi? At what RPM? That seems a little high.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Jul 8, 2001 | 03:39 PM
Jester's Avatar
Pretty much anything above idle. Melling 55 w/ HP relief spring on an all new motor.
JSP Motorsports
ICON Motorsports
Old Jul 8, 2001 | 10:08 PM
Bobalos's Avatar
the OP is a bit excessive, but I dont think that it will hurt the Turbo's. they push through an orifice & I am sure that it does not like that OP all the time but I can not see that it is a big deal. I think that it is more likely to get hurt if the return line is too small or kinked.
I am not a turbo Guru, but that makes pretty fair sense to me.
BW
Old Jul 9, 2001 | 02:11 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Make sure the return line isnt kinked. The return line MUST go in the pan ABOVE the oil level. If not, the oil coming out of the turbo will get backed up in the line and push its way past the seals.
Old Jul 9, 2001 | 10:25 AM
ATOMonkey's Avatar
Oil Pressure isn't so high. I'm running the same right now. I don't think the stock gauges are 100% reliable. A good rule of thumb is 10 psi per 1000 RPM.
'87 Bird 350 .060 over 700R4 + Lots more
Old Jul 9, 2001 | 01:14 PM
Jester's Avatar
The return line uses 1/2" fittings. no kinks or anything. I wasn't sure if 1/4" under high pressuse would deliver too much oil even for that to handle without leaking out of the shafts.
JSP Motorsports
ICON Motorsports
Old Jul 10, 2001 | 07:19 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
I don't think you're getting too much oil - seems fine to me. Like what was said - you need a big, clean, non-horizontal run drain line. For reference, my oil comes from the oil plug near the top of the bellhousing from a T (I think 1/8 NPT to -4AN), -4AN lines to a -4AN/ -1/8NPT elbow into the turbos. The drain is a vertical 1/2" NPT/-10AN fitting to -10AN line, to a -10/-1/2" NPT 45 degree into the oil pan at the front, above the oil level.
A.
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
