730 or 749
Old May 27, 2006 | 12:46 PM
jocool's Avatar
Car: 89 Iroc & 88 Firecird & 86 Camaro
Engine: 350 TPI & 305 TBI & 305 Carb
730 or 749
This might be a stupid question but what's the difference between running a 730 ecm with the 58 code and running a 749 with the 730 memcal? The reason I ask is because I want to retain my VATS. With a 2 bar map can the 730 sense boost?
Old May 27, 2006 | 01:08 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
the code is entirely different, the 7730 $8D code doesnt sense boost, the $58 code does, the ecm's are identical aside from a few wires.
Old May 27, 2006 | 02:16 PM
jocool's Avatar
Can I retain VATS with $58 code?
Old May 27, 2006 | 05:47 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
no $58 doesnt support vats, vats isnt that good of a security device anyhow, do some searches, you'll find everything you need to know.
Old May 27, 2006 | 08:22 PM
jocool's Avatar
A couple years ago someone tried to steal my car and it kept them from getting away with it. Thank you for the quick responses and info 86Z.
junkcltr
26
Jan 22, 2022 10:53 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
355tpipickup
Aug 19, 2015 10:02 PM
SATURN5
Jan 25, 2001 12:07 AM
