What is the best piston for nitrous?
Old Nov 30, 2001 | 10:05 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Transmission: TH700-R4
I was wondering what the best piston to use for nitrous,like forged with dished or flat top,etc.?What about brand?
91 Camaro Z/28 5.7
NX kit
3" exhaust with Flowmaster DeltFlow 40series
SLP runners
SLP 1 5/8" headers
TPIS airfoil
K&Ns with gutted airbox
Jet low temp. fan switch and 180 degree thermostat
Rebuilt 700R4(borg warner/raybestos clutches,Kevlar band,vette servo)
B&M 2400 stall torque converter
renegaderacing.cz28.com
Old Dec 2, 2001 | 04:34 PM
SoCo80p's Avatar
a good strong forged unit only, depends on how much you want to spray it, for about 75-150 a flattop will be fine and keep the compressions around 9:1 or 9.5:1 if its a bigger shot go dished.
Old Dec 2, 2001 | 04:44 PM
IROCZ383TRS's Avatar
i ran a set of speed pro forged pistons, and i had a 2 stage NOS FOGGER SYSTEM.... so they hold up pertty well...
Old Dec 2, 2001 | 04:59 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
we use alot of nitrous here, we are a nitrous express dealer. we believe that the proper amount of nitrous is one jet setting lower than it takes to fold the piston over the pin, which happens alot. once you learn how to not burn, blow, or detonate an engine on 750 horse of juice the next step is keeping it sealed in the engine and how much the parts can take. other than expensive made to order flat top nitrous pistons that have an extra thick top and special ring packaging, there is only one, TRW forged or as its known now federal mogul forged. these pistons are as tough as anvils and are very forgiving but heavy. stay with the flatop because domes and dishes seem to give the massive cylinder pressure strange leverages that allow it to FUBAR the top of the piston also avoid the "fully machined" versions denoted with a "M" following the "F" in the beggining of the part # or an "LW". also remember ring end gap is more important than the type or cost of the rings used. it must be bordering on excessive to keep the ends from butting and ripping off the top of the piston, also never use a ring that is full circle i.e. total seal. a gas build up between the top and bottom rings on blown or nitroused engines can rip the top of the piston off.
Old Dec 2, 2001 | 06:25 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Thanks for the info
Old Feb 17, 2002 | 09:30 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
B4com1,
Could you please tell me why the pistons with part numbers beginning with an "LW" are bad? What rings would you recommend then?? Thanks
Old Feb 20, 2002 | 10:19 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
its not so much that they are bad it is that they are lighter, hence less anvil for your pounding. I have actually had great results with both just go for the L first and the LW second and dont forget to give the custom manufacturers a try too (sarcastically)for the paltry sum of a few hundred dollars more (twice the price, sometimes) they can build to order just for you, a thick topped piston with repositioned rings that will give you identical strength and wieght of the cheaper TRW's for your troubles and then tell you not to run more than 125 to 250 hp on it (depending on manufacturer) or they wont stand behind thier work.
Old Feb 20, 2002 | 10:20 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
rings is a pretty sticky subject (I.E. can O' worms) just remember to run excessive ring clearances if you plan on running excessive nitrous or even if you dont plan on it, it could save your motor.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Dragonsys
Sep 25, 2015 03:51 PM
