Performance chip- How well do they work?
Old Dec 12, 2001 | 01:30 PM
305IrocZ28's Avatar
Car: 1990 IROC-Z
Transmission: 700-R4
I am going to be purchasing an upgrade chip for my car, and I was wondering how well they work. I have been looking into the Fastchip- any testimonials? If anyone hasnt used this, what other models have you used and how well do they work? What exactly will it affect, and what kind of 0-60 improvement should I expect? Do any other mods have to be done to the car before I install the chip?
305IrocZ28- Al
1990 Iroc-Z
305 TPI
0-60 in 6.8 (timed)
2.73 Posi (3.42 or 3.73 to come)
Flowmaster exhaust
T-tops
Red w/ black racing stripes
Pioneer headunit, stock speakers, Rockford 10'' punch woofers
Ricers beware...I eat you three meals a day
And the Camaro said to the Civic "Now, I know what you're thinking...in all of that mess, did he have 8 cylinders, or only 6? You just gotta ask yourself one question...do you feel lucky? Well do ya....punk???
Old Dec 12, 2001 | 09:51 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Looks like a good question to ask on the ECM board,
https://www.thirdgen.org/cgi-bin/mes...r=31&SUBMIT=Go
Most affect wide open throttle air/fuel ratio and ignition timing, some turn on the cooling fan at a cooler temp.
You will get more answers on the ECM board though.
Old Dec 14, 2001 | 12:51 PM
Z28DJP1987's Avatar
Good Luck on asking about a stock Chip on that Board. All they will tell you,"a stock Chip sucks and burn your own".
Old Dec 14, 2001 | 02:10 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
i had a stage 2 fastchip, i like it, made a nice difference from like 3K rpms + pulled harder. I'm probably ditching the whole L98 anyway and going turbo 3.8
*89 Trans Am GTA
*Moderator at www.transamgta.com
To hell with the GM vs Ford war. We must unite, as brothers to fight the plague that is overtaking the world...RICE
Tony
Old Dec 14, 2001 | 04:52 PM
IROCKZ4me's Avatar
Originally posted by Z28DJP1987:
<font face="Verdana, Arial" size="2">Good Luck on asking about a stock Chip on that Board. All they will tell you,"a stock Chip sucks and burn your own".
</font>
LOL, that sounds more like the reply they give (and you would expect) on the " DIY PROM (do it yourself PROM)" board when someone asks about a generic store bought chip.
The ECM board would be the place to ask.
There are two reasons they give that reply.
1. It isn't the "store bought PROM" board. It's the DIY PROM board.
2. It's completely true.
There is no way that a store bought PROM that was burned to calibrate the air/fuel mix and spark for a stock engine at wide open throttle while keeping the stock GM calibration at part throttle to comply with the EPA is going to work best on an engine with modifications.
The ECM board would be a better place to ask than the Power Adder board.
A "power adder" = forced induction, like superchargers, turbochargers, nitrous oxide etc.
A "power adder" is not a chip, K&N filter, cam, throttle body, chrome valve covers, etc.
A chip question posted here should relate only to the calibration for an engine with a power adder. Even then you would be better off to post the same Q on the ECM or PROM boards as well, because more "chip Experts" hang out there than here.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
Old Dec 14, 2001 | 05:00 PM
IROCKZ4me's Avatar
Just a possible $ and power tip too:
Many have found that adjusting the fuel pressure with an adjustable regulator and tweaking the base ignition timing while using a stock chip, gets a better HP gain than just putting in an "over the counter" store bought chip.
The regulator and a timing light + a test&tune sesion at the drag strip is cheaper than a chip. Your ride will be quicker and you'll have enough pocket change left over to take your chic to a flick.
[This message has been edited by IROCKZ4me (edited December 14, 2001).]
Old Dec 25, 2001 | 12:55 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I liked the results I got on my 85 tpi from the hypertech thermomaster chip, thermostat, tpis air foil, k&ns, cutout air filter boxes, mass air without vanes and screens, vette/4.3 v6 converter (#7 stamped converter housing), solid rod end control arms, no front sway bar, dead old front struts, 3:73 gears, and hollowed cat = 14.50 at 90 mph at sears point raceway. the bad part of the combo on this car was no subframe connectors, bald 295/50/15 bfg t/a's, and open (no posi) diff.
Old Dec 25, 2001 | 04:55 PM
JR4444's Avatar
These results are from a stock 305 out of a 1991 Camaro (same enging as yours I believe)
CHIP ET MPH
Performance Resource 14.67 94.4
Guldstrand Engineering 14.79 93.3
GM Performance Chip 14.81 93.0
ADS 14.90 92.7
TPI Specialists Level 2 14.98 92.4
Hypertech Stage 1 15.01 92.4
This is from a Mag. article on this site.
Vintageracer
Jan 10, 2020 05:33 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
